Holset Turbo... HELP!
Old Aug 12, 2009 | 11:18 AM
str8laced82's Avatar
Default Holset Turbo... HELP!
Does anyone know if you can set up a compound system by adding and HX40 to the existing HE351? If so what would it take.
I pulled my HX40 out of my '02 when I rolled it and was wanting to put it to use.
Old Aug 12, 2009 | 11:25 AM
kazairl's Avatar
You can sell it thats about all you can do with it.
Old Nov 17, 2009 | 06:47 PM
geauxsimon's Avatar
I got a question about my turbo. Its a holset that I bought off ebay. THe guy said it was a hx30. The holsets i have seen hava snap ring that holds the compressor housing on. Mine has a few metal bar type things that hold it on with bolts. Does anyone know if I could replace the housing with the hx35 housing and wheels and use a snap ring instead
heres a pic to show you what I am talking about. It the cool side
Last edited by geauxsimon; Nov 17, 2009 at 06:47 PM. Reason: Automerged Doublepost
Old Nov 17, 2009 | 06:48 PM
12vcummins96's Avatar
not sure but probably not but maybe someone will chime in that will have a better idea
Old Nov 17, 2009 | 07:05 PM
You could probably bought a HX35 for cheaper than what ya paid for that turbo.
Old Nov 17, 2009 | 10:39 PM
mxtuner1's Avatar
Default hx40
hx40 would not be a good mesh with your he351. They flow almost the same and you would just be complicating your setup. I would suggest to decide how much boost you want- and get an appropriate turbo to reach that level. Also, the stock head gasket on the 2006 should be good to 40-50lbs of boost- above that need head studs. Remember the turbo is the most restrictive item on your whole engine - free up some flow and the dyno will become your friend.
avatardvr
18
Aug 8, 2019 12:38 AM
Cumminsfreak24
May 6, 2015 04:56 PM
truckeez
For Sale
Mar 3, 2015 05:54 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
