3000 or 4000 rpm p pump governor springs
Old Aug 9, 2009 | 07:46 PM
st_jsmith01's Avatar
Default 3000 or 4000 rpm p pump governor springs
just want some input such as is it worth it how hard to put em in so on and so forth. Thanks for any input
Old Aug 9, 2009 | 08:33 PM
hunter's Avatar
well man the best way to do it would be to put 4gsk and 60 lbs valve springs in all at once it cost u just as much to do a 3gsk as a 4gsk so u should do it at once imho
Old Aug 9, 2009 | 08:39 PM
biged681985's Avatar
imo, get the 4k gsk. u can have the 4k gsk set at 3k by leaving one spring out. the cheapest p;ace ive found is from one of our sponsers here. hit tony up at mightydiesel
Old Aug 9, 2009 | 08:46 PM
do i need the 60 lbs valve springs??? and are the 370s on your sig. the 370 marine injectors?
Old Aug 9, 2009 | 08:52 PM
hunter's Avatar
yes if ur running the 4gsk than u will need 60lbs springs and yes they are marine 370s but there are two different kind there are 70hp and 90hp i have the 90hp
Old Aug 9, 2009 | 08:55 PM
you like em alright?
Old Aug 9, 2009 | 08:59 PM
hunter's Avatar
oh yeah what kind of turbo are u runnin
Old Aug 9, 2009 | 09:06 PM
xzaq103's Avatar
FormerVendor
370s are 5X12s
Make sure you get correct spray injectors 145* not 155* the marine nozzels dont spray in the bowl create heat and smoke as well as bad MPG. You can get corect spray 5X12s for just about the same price as marine 370s.
Old Aug 9, 2009 | 10:14 PM
Originally Posted by xzaq103
370s are 5X12s
where can i find 5x12s?
stock right now. i just really love rolling coal
Last edited by st_jsmith01; Aug 9, 2009 at 10:14 PM. Reason: Automerged Doublepost
cgraham
Aug 4, 2015 07:50 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
