trailer towing
Old Aug 9, 2009 | 03:39 PM
hunter's Avatar
Default trailer towing
so i towed my trailer yesterday,and i did it with my play truck the one in my sig. i was pulling a 24 foot two axle non gooseneck.and i had a 69 c10 loaded down and it deffently didnt have the power i was expecting,better than my daily driver but not as much as i hopedany suggestions
Old Aug 19, 2009 | 11:19 PM
coyropin's Avatar
air filter fuel filter it looks like your truck can work check the easy stuff first
Old Aug 20, 2009 | 12:57 AM
toy4xchris's Avatar
not to sound off base but what kind of power were you expecting?
what kind of trans?
Old Aug 20, 2009 | 01:33 AM
94cummins12v's Avatar
i have the same setup as you and i have noticed the same thing, that it doesnt pull as hard as we would like to, i found out with these super phatshaft and 370 combos with the 191 dvs that 15-20psi pulles better than 25-30psi, i was pulling 14k the other day and noticed that 17psi was running better with cooler temps than 23psi
Old Aug 20, 2009 | 10:10 PM
hunter's Avatar
a nv4500 it should pull better than any atuto
Old Aug 20, 2009 | 10:23 PM
it does i can control the spool a bit better than what my budy can with an auto
Old Aug 20, 2009 | 10:26 PM
sidekick's Avatar
what do you call good or bad 0-55 in 3 miles or 10 feet?
Old Aug 20, 2009 | 10:29 PM
i dont know anyone that can do 0-55 in 10 feet, i can get 30k up to 60 in as much distance as it takes my 87 chevy to get the same speed empty
Old Aug 21, 2009 | 09:37 AM
Hammer's Avatar
First lets start with this.....
You guys have been tuning for power and not towing,there is a difference,a HUGE difference.One can not expect a truck that has a max fuel tune to be able to tow your big trailers around without any expectancy of lag or temps.To gain in one area you will always loose in the other and with a 12v's timing be fixed there is no way to help light all the heavy fuel down low to make your truck tow like it runs unloaded.
INCORRECT!....
A properly built automatic and a lock up switch will destroy a NV series tranny when it come to towing.By the time you get rowed though the box the automatic owner will have his load moving and leave you sitting wondering why you didn't build a automatic truck instead.
Old Aug 21, 2009 | 10:19 AM
biged681985's Avatar
very well put hammer
