TC lockup switch
Old Aug 9, 2009 | 12:43 AM
zrendel's Avatar
Default TC lockup switch
ok so i installed a lockup switch on my 02 dodge. everything went perfect. works great. locks in when its supposed to and locks out like its supposed to. but the only thing is im throwing codes now.. the codes im getting is 0622 generator field control circuit, 0743 torque converter clutch circuit, 1765 transmission 12 volt supply relay control circuit, and 1693 companion code. so my question is will the truck start having these codes now that the switch is installed or did i screw something up???
Old Aug 9, 2009 | 01:07 AM
Fishin2Deep4U's Avatar
Nope. The codes are "normal" They will have no effect on power output, but when you force voltage when the PCM is not giving the orders, you get codes.
I know some guys have used diodes and resistors to stop the codes, but they will have no ill effects on your ride and will clear after a few starts.
Dave
Old Aug 9, 2009 | 01:09 AM
zrendel's Avatar
ok awesome!! i figured that it was just from that. but ya ill probably add one of those just to help out some. but thanks!!
Zack
Old Aug 9, 2009 | 03:01 AM
Be careful using that TC Lockup Switch on a stock transmission. It can be easy to break a shaft if you lock the TC during shifts.
Old Aug 10, 2009 | 01:59 AM
Ed ke6bnl's Avatar
I have a DTT trans with a exhaust brake and I get the same codes when I use the exhaust brake that also will lock up the torque converter. Bothersome but not sure if there is a way out of the problem. I have gotten use to it and after a few start ups the codes seem to clear themself. ED I thought it was a california truck thing.
Old Aug 10, 2009 | 01:54 PM
01quadcab's Avatar
did you do the jumper wire in the fuse box?
Old Aug 10, 2009 | 03:00 PM
Ed ke6bnl's Avatar
Mine was done with the transmission and exhaust brake install per previous owner
Old Aug 10, 2009 | 05:22 PM
zrendel's Avatar
ya i ran the jumper in the fuse box.
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
7.3lfordguy
8
Oct 17, 2014 11:45 PM
