injectors.
Old Aug 3, 2009 | 11:35 AM
young gun's Avatar
Default injectors.
im just curious and not relly looking into them yet but 1 how hard are they to install? 2 i dont tow anything i just want more power so what would be a good set that wont tank my mpg? 3 should i look into a bigger turbo before bigger injectors?
Old Aug 3, 2009 | 11:54 AM
TwinStackPete379's Avatar
hmm.. well they arnt hard to install. you HAVE to make sure you get the injector bore cleaned out or youll be pulling them out again to reseal them. i would get new copper washers anyway imo. remove the lines ( KEEP clamps on them so they will be lined up with pump and injectors) what year truck you have ? i dont see a sig. i put some 215s in my old 96 that was an 180 hp truck. that actually helped out abunch. kept it real cool. i tweeked the afcalong with that.
Old Aug 3, 2009 | 12:04 PM
young gun's Avatar
its a 98 with a twelve valve. 3500 ext cab long bed dually 4x4 auto
Old Aug 3, 2009 | 12:16 PM
sounds like a nice ride. well you might look into ddp they have a nice 90 horse injector. i dont have them but i have a 370 new era. i still think youll need a charger to get full benifit from them. it will run pretty warm with the stock charger on it. you might be somewhat ok with some afc tuning. if your not doing anything with it except driving it you could get by with just watching the temps but imo youll need more air. more fellas will chip in . hopefully they can help you more than me. just something to think abot
your tranny will most likely not like it tho
Last edited by TwinStackPete379; Aug 3, 2009 at 12:16 PM. Reason: Automerged Doublepost
Old Aug 3, 2009 | 01:47 PM
BAD ASS RAM's Avatar
that should be a 180 pump.get the DDP's.and if you're gonna pull anything you really need a charger,i could'nt go up a good grade empty without gettin hot before i got the hybrid.
Old Aug 3, 2009 | 02:44 PM
young gun's Avatar
yeah i definnently thought bout it. and i know i gotta get more air. just i need to save up my money to get it. is there a way to make my stock turbo a high pressure turbo and then get like a hx40 turbo as a low pressure turbo for a twin setup. i dont know much bout them thats why im askin
Old Aug 3, 2009 | 03:34 PM
12valvetater's Avatar
a 40 is too small imo for a low press charger you should get either an s400 with a small exhaust housing or an ht3b
Old Aug 3, 2009 | 03:57 PM
young gun's Avatar
whats a s400 cost roughly?
Old Aug 3, 2009 | 05:28 PM
xzaq103's Avatar
FormerVendor
If you tow anyting "heavy" and want to keep the stock charger look for some 215s or 5X10s For mild towing with a stocker and your able to keep you foot out of it some 5X12s if you want to step up to a single go with an S300 maybe a 62/6, 62/71, 64/65 or a 64/71 All of these would be a good match for 5X12s or 5X14s if your going the 62/71 or 64/71 route.
Old Aug 3, 2009 | 08:19 PM
young gun's Avatar
well im not sure yet but here is a question. could i swabp my turbo out for a hx40. like would it be just remove and install or would the bolt holes not even line up. cause if i can get more air by doing that ill look into some 120 horse injectors or 150s. cause i still wanna smoke alot cause im gettin stacks and there is no point to stacks if you dont smoke, so ill get big injectors so i still get the power and the smoke will belch.
