need help asap installing this turbo
Old Jul 23, 2009 | 09:04 PM
CATCRACKER's Avatar
Default need help asap installing this turbo
got the old turbo off and i just took off the exhast elbow to put it on the new htt 64 71 13ss and it has 2 little **** made to fit into the back of the exhaust housing and the new turbo doesnt have any holes to slide into it. do i just grind off the **** off of the the old elbow??
thanks for any help you can give i need to get this turbo on the truck tommorow
i will be check this every 15 minutes
Old Jul 23, 2009 | 09:09 PM
sidekick's Avatar
yes just grind them off flat
Old Jul 23, 2009 | 09:25 PM
CATCRACKER's Avatar
you the man
Old Jul 23, 2009 | 09:31 PM
sidekick's Avatar
hope you get it on let us know how you like it
Old Jul 30, 2009 | 10:35 PM
rossk's Avatar
they pull out with pliers
Old Jul 31, 2009 | 12:00 PM
sidekick's Avatar
yea but that leaves 2 small voids that i have seen crack and then you have to get a new elbow. if you grind off than it is less likely to blow out, seen to many break with them out
Old Jul 31, 2009 | 02:41 PM
CATCRACKER's Avatar
man its a great turbo. i dont have stick in yet and that should wake the bottom end up. i also have not installed my air dog yet.
so here are a few notes/tips for those who care:
-jacking the truck up taking, tire, battery and wheel liner out is a must.
-pb blaster is worth at least $100 per bottle
-knee pads are a must when you are on top of the motor
-take turbo off with manifold
-the bolt that holds the water heater bracket is a real sob
-which bring up the point off a good sawall. three things got the sawzall 1.heater hose bracket 2. lifting lug 3. exhaust bracket that attatches to the tranny
-leave the elbow off when installing turbo
-dont clock the turbo if its from htt b/c its probably right on.
i still need help does anyone know if i can clock this turbo while still on the truck???
oh yea it sounds like an f-16 is following me around
Old Jul 31, 2009 | 03:34 PM
1badcummins's Avatar
sounds like fun cant wait till i get a new turbo or two
Old Jul 31, 2009 | 03:57 PM
sidekick's Avatar
cool deal my wife is pissed we went on a few hundred mile trip and that is all she heard was the turbo
Old Aug 5, 2009 | 11:34 PM
CATCRACKER's Avatar
also i just clocked the turbo while still on the truck!! all perfect now
