HELP!!
Old Jul 22, 2009 | 08:13 PM
kfarris's Avatar
Angry HELP!!
I've got a 7.5 6.7L and the DPF went missing a few months ago. Have had no problems with my H&S delete until recent. Truck is trying to regen and I can't figure out why. James with RSD is sending me some new SIMS but I ohmed out my current SIMS and they are all the same. The EDGE clears all codes on startup so there is no CEL but as soon as I drive about a 1/4 mile, she starts smoking like hell and the Edge is alerting that a regen is taking place. Then I get a "DPF Ristriction-Ash Accumulation" code.
Anybody have any ideas? I'm afraid to drive the truck and not havins wheels is killing me.
Old Jul 23, 2009 | 03:03 PM
brk126's Avatar
from what H&S tells me you cannot stack the XRT with anything else like an edge.....
Old Jul 23, 2009 | 03:42 PM
ETXBlueRam's Avatar
I don't think he's running the XRT.
The extra smoke is from the 4th injection cycle not being turned off. Sounds like it's still trying to go into regen mode.
I'd get in touch with Casey at H&S. I'm sure he'll get you pointed in the right direction.
Old Jul 23, 2009 | 08:08 PM
kfarris's Avatar
I drove the truck today and as expected she tried to regen...stalled a little and it sounded like the exhaust brake was on, but it wasn't. It quit after about 5 minutes and has been fine all day but I expect the problem will return. I am hoping RSD will get me the updated SIMS. From what I hear they have some sort of counter that resets the emission. Guess I should just get the new Smarty and be done with it....
Old Jul 24, 2009 | 09:00 AM
WOODLIZZARD's Avatar
Smarty or XRT man. Either way and nore more problems!
Old Jul 25, 2009 | 07:30 PM
ETXBlueRam's Avatar
Sounds to me like the SIMS are what is causing your problem. Regeneration isn't dictated by a counter, but by the signal it receives from the sensors in your exhaust. If it senses the flow/pressure to be outside acceptable limits...it tells the computer the DPF needs to be cleaned out...so it goes into regen. The sims act as a fooler telling the ECM that everything is fine.
It may be possible that your turbo is dirty and hanging up a bit when you started it. Depending on the vane position it can make it sound like the exhuast brake is on.
If you can swing it, I'd go ahead and get a Smarty or XRT and not have to worry about those problems anymore. I haven't had any codes at all since I installed ME14 software(latest update) on my Smarty. As of this weekend, I have access to an XRT also, so I'll get to see firsthand how it does as well.
Hopefully you'll get all your bugs worked out pretty soon.
Old Jul 26, 2009 | 10:01 PM
brk126's Avatar
oooo i saw that he was using the H&S delete just figured he was running the XRT.....My bad
Old Jul 27, 2009 | 04:10 PM
kfarris's Avatar
OK, still waiting on my new Sims so at least I can get my truck back to normal. For a good fix, was considering the XRT but these guys are taking their sweet time helping me out of this jam so I am back to he Smarty. Any preferences out there?
Old Jul 28, 2009 | 01:07 AM
ETXBlueRam's Avatar
I sent you a PM with some info that will help you out.
JB
Old Jul 31, 2009 | 08:40 PM
kfarris's Avatar
New sims arrived and I'm all good....No codes
Sure 'nough gonna get me one o' them Smarty's though.
