i need help bad
Old Jul 22, 2009 | 10:20 AM
tpost's Avatar
Default i need help bad
went out to start truck have power every where but to starter. When turning the ignition to start position and shove clutch in, the starter does nothing what is my problem
Old Jul 22, 2009 | 11:34 AM
wildbill's Avatar
Sounds like the switch on the clutch pedal is either out of adjustment or needs replaced.
Old Jul 22, 2009 | 11:37 AM
stkdram55's Avatar
no clicks or nothing?? Then ya your not getting any power actually to the starter...check the clutch saftey switch check your connections that everything is tight at the starter...
Old Jul 22, 2009 | 09:39 PM
coyropin's Avatar
check to see if your starter relay has power if not you hane blown a fuse in the fuse panel under the hood
Old Jul 22, 2009 | 09:43 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
jump around switch on clutch and see if it will crank
Old Jul 23, 2009 | 07:31 AM
tpost's Avatar
thanks for all the help got her fixed it ended up being weak batteries cause everything else checked out agaian thanks for all the help
Old Jul 23, 2009 | 05:02 PM
wildbill's Avatar
Sounds good!! Will close the thread.
|WYG|SS
Jul 26, 2015 11:18 AM
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
