4k kit install
Old Jul 20, 2009 | 10:50 PM
dan33klein's Avatar
Default 4k kit install
hey guys i got my 4k kit today.
how are you supposed to see inside that hole and get the springs and all the seats out of the hole when its under the fuel shut off solenoid?
you can even begin to see down there.?
Old Jul 20, 2009 | 11:15 PM
12valvetater's Avatar
you take the selnoid off and use a magnet
Old Jul 20, 2009 | 11:55 PM
dan33klein's Avatar
ok because i wasnt sure.
can you get a nice pencil magnet like a craftmen one from sears?
what about the caliper?
Old Jul 21, 2009 | 12:11 AM
This is for 3k springs but it should still help you out:
PDR governor spring installation
Old Jul 21, 2009 | 01:27 PM
yeah i got my craftsmen magnets from sears
Old Jul 21, 2009 | 03:26 PM
davo79's Avatar
Don't forget to take the shutofff valve arm off but be really careful not to lose the keyway off the shaft the plug will come out with the arm on but you'll never get it back on
Old Jul 21, 2009 | 04:14 PM
dan33klein's Avatar
which is easier going through that plug hole?
or from under the fuel plate?
Old Jul 24, 2009 | 06:20 PM
9412Valve's Avatar
I got my pencil magnet and caliper from sears . Any luck with the install? Go through the plug hole.
Old Jul 24, 2009 | 09:14 PM
WangoTango's Avatar
Default Re
through the plug (under shutoff selanoid) is quickest+easiest, that where there is little to no risk dropping the springs, and if you dont have a caliper count the clicks, and if that fails (which i couldnt feel the clicks when i took mine off) just throw them back in the pump [!make sure you use the new rear springs seats!] and put er back together, i first fired mine up and it revved all the way up to 2k+ at idle, so i backed off the adjuster nut a couple of time and it was trial and error and after 3 times i finally have it idling a little under what stock was, Really was worth it, its revs up alot higher quicker!
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
Apr 29, 2015 08:20 AM
slowstroke
For Sale
Mar 27, 2015 05:19 PM
Gman30
Dec 27, 2014 12:46 PM
TyCarp
Dec 10, 2014 11:02 AM
