Valve Spring Replacement
Old Jul 19, 2009 | 11:29 PM
dan33klein's Avatar
Default Valve Spring Replacement
my 60lb valve springs are gunna be hear tommorow and i didnt know if i can just rent your everyday valve spring compressor or if you need a speacial one. i know how to rotate the engine for tdc and all that good stuff.
i just want some tips or advice to change them out nice and smooth.
and any tips on installing the 4k kit are welcome to!
thanks
Old Jul 20, 2009 | 01:01 AM
94cummins12v's Avatar
you can get the valve spring compressor from harbor freight for about $15. once you get the #1 and at TDC #6 is there also. pop the spring off to get the keepers out and the valve wont fall into the cylander becasue the pistons are at the top. rotate the crank 120* (correct me if im wrong) to get the #2 and #5 close to TDC then rotate another 120* to get the #3 and #4 at TDC its a farly easy operation to do
Old Jul 20, 2009 | 07:28 AM
dan33klein's Avatar
i dont have a harbor freight in my area. im just gunna pick up one from autozone.
and how do the cylinders appear?
#1 front of truck #6 rear?
Old Jul 20, 2009 | 10:25 AM
ya the first cylander #1 and last #6 are always at the same hieght as is #2 and #5, then #3 and #4
Old Jul 20, 2009 | 01:59 PM
davo79's Avatar
Good luck with the autozone compressor they aren't worth the crappy steel they stamp em out of. Go to napa and get the kd tools compressor or you'll never get 5 and 6 without pullin your motor
Old Jul 20, 2009 | 03:48 PM
dan33klein's Avatar
kk i got a nappa..
ill used the kd compressor thanks
Old Jul 20, 2009 | 04:10 PM
9412Valve's Avatar
Haven't done the valve springs on mine yet.. I just did the 3k gsk last friday - pretty easy, just make sure you get a decent pencil magnet and vernier calipers - makes it alot easier! other than that, just follow the directions in the box :P.
Old Jul 20, 2009 | 10:49 PM
dan33klein's Avatar
well i dont have the calipers..
i do have the magnet tho
does anyone one the torque specifications of the bolts on the rocker arms?
any tips on removing then or the springs?
Last edited by dan33klein; Jul 20, 2009 at 10:49 PM. Reason: Automerged Doublepost
Old Jul 21, 2009 | 12:19 AM
the big bolts are supposed to be the same as the rest of the head bolts i belive there 89ft-lbs +90* but im used to torquing my studs to 150ftlbs so i may be wrong
Old Jul 21, 2009 | 01:34 PM
12valvetater's Avatar
the little ones are something like 14 pounds i think
