99' power issue.
Old Jul 15, 2009 | 09:32 AM
captainwinger's Avatar
Default 99' power issue.
Mornin'
I have a 99' 7.3 with what I "think" having turbo issues... Here's the story..
Going down the interstate running perfect then engine suddenly shut down. Wouldn't start up till cooled off a tad. Started then made it a 1/4 mile. Hooked to computer and found cam position sensor fault. Changed and ran again, but not rite. It missed at idle (only on start up) and was sluggish going over hills. Hooked back to computer and no codes. Drove for a couple days then started shutting down regularly at idle and up to speed from time to time. Had to power brake while stopped to keep running then seemed to run fine under way. Hooked back to computer cleared all existing codes then pulled a P0470. Exhaust back pressure is 38 at idle.. Truck now acts like it has no boost. Feels like it's building but not releasing. Hope this makes sense..
Any help will be beyond appreciated....
Nick
Old Jul 16, 2009 | 04:14 PM
RSWORDS's Avatar
hhhmmm.... I'm going to let one of the powerstorke guys handle this one.
Old Jul 16, 2009 | 07:35 PM
Deputydog's Avatar
If there was a turbo issue, I think you'd be seeing lots of black smoke. Sounds like its more of a HPOP (high pressure oil) issue to me. Have you watch the ICP on the scanner to see what it is doing?
Old Jul 16, 2009 | 07:59 PM
Woody35's Avatar
wastegate problems?
Old Jul 16, 2009 | 08:25 PM
Superstroker10's Avatar
deputy and i are on the same page. you need to check and see what your icp and duty cycle are. do you have a scan gauge or anything similar?
Old Jul 17, 2009 | 12:51 PM
Ok... I cleared the existing code then drove again. Zero black smoke but ran like turbo was kicking in too soon and was surging pretty bad. Opposite from last.. It would get sluggish then take off with boost then get sluggish again. Kinda like the way my ol' lady cleans the house.... Crazy!!
Anyway, Ran another scan and got same code P0470. While running the self test i think during the wastegate opening part it fell on its face and threw a P1284. ICP fault aborts koer cct test.
Old Jul 19, 2009 | 10:14 PM
CSIPSD's Avatar
You have a HPOP issue not a turbo issue. Check your ICP pressure, Duty cycle and such...
Old Aug 3, 2009 | 03:01 AM
blk99's Avatar
make sure the IPR is tight.... it will do ALL KINDS of weird things if that comes loose or the wiring is loose.... trust me, i know...
ramrunner01
Jun 1, 2015 12:10 AM
big tan snorkel
15
Dec 17, 2014 05:04 PM
