ball joints for a ford F-250 4x4
Old Jul 14, 2009 | 02:37 PM
crewed powerstroke's Avatar
Default ball joints for a ford F-250 4x4
What is the easiest way to change ball joints on a 2006 F-250 4X4 ? (both upper and lower)
And what brands seem to hold up the best ? Any hints or suggestions would be appreciated . Thanks
Old Jul 16, 2009 | 04:16 PM
RSWORDS's Avatar
Get a ball joint joint install/remover tool and go to town! should not be too hard.
Old Jul 17, 2009 | 12:06 AM
LOGANSTANFORTH's Avatar
Moog or Ford......either will work......get an electric or air impact and a balljoint set like Bobby suggested......trust me on this, use an impact, its 10X's easier......
Old Jul 26, 2009 | 12:21 AM
Big Angry Hillbilly's Avatar
Nobody has mentioned you need to take the wheel bearing and axle assembly out of each side to get the spindle off.
You should replace the outer hub seals on the axle, and the O-rings on the hub bearing to make sure the ESOF still works.
A lot of times, you have to beat those hub seals up pretty bad to get the axles out, but I ususally only see 'em while they're still under warranty, so I change 'em regardless.
Old Jul 26, 2009 | 07:56 PM
Thanks ! The front suspension doesn't have the same warranty as the engine by any chance does it ? I.E. 100,000 mi.? Today I got my first experience with the famed death wobble while pulling a trailer . That was a real treat . I figure it's about time to start changing suspension parts at almost 90,000 mi . Thanks again .
Old Jul 27, 2009 | 11:52 PM
Bigstuck's Avatar
There easy enough. And the hub seals on the outer axle stub dont get beat up if your careful. Either use a rubber mallet and hit the ear of the joint and they will slide out or use 2 pry bar opposing each other on the ears of the joint and it will pop out just as easy. Spray lube always makes things come out much easier too.
Old Jul 30, 2009 | 09:58 PM
tsambo212's Avatar
i had a ford and had to replace those dang ball joints every 60k
Sep 15, 2015 07:40 AM
LawdawgSHPD
Aug 21, 2015 06:23 PM
99RAMS
Jan 25, 2015 11:31 PM
Oct 14, 2014 08:40 AM
