abs brake light with soft pedal
Old Jul 13, 2009 | 06:22 PM
Spec-curios's Avatar
Default abs brake light with soft pedal
I am having an issue with my 97 dodge 12v where my abs brake light come on when I apply the brake. I can tap the pedal and it will shut off, though comes on again when I reapply the brake. Also has a soft pedal for about 3 inch push before it goes to norm resistance. I have read the closed forums and none of those solutions seem to be mine. Any ideas would be helpful. Thanks
Old Jul 13, 2009 | 08:06 PM
bryson's Avatar
The light comes on if there is a difference in pressure between front and rear brakes, so it sounds like there is air in the system somewhere...? Or there may be a leak somewhere. Can you see any leaks in any lines? The wheel cylinders inside your rear drums can leak and go unnoticed for a while... Check also the boot on the inside of the firewall where the rod from the brake pedal goes into the master cylinder, as the MC can leak back into the cab.
Basically, make sure the master cylinder is full of fluid, and if you find no leaks, try bleeding the system.
But.....You say you can push the pedal about 3" and then pedal goes to normal? That makes me think there is a good chance it is the master cylinder...
Old Jul 14, 2009 | 02:16 AM
gradyc's Avatar
that much peddle travel could also be the rear brakes way out of adjustment or broken hardware or a front wheel bearing getting loose and allowing the rotor to push the piston too far into the caliper
Old Jul 15, 2009 | 08:47 PM
wildbill's Avatar
Leaking brake line??
Old Jul 15, 2009 | 09:27 PM
All it took was a brake system flush. Apparently, there was a bit of grit in the lines. Thanks for the help.
Old Jul 15, 2009 | 10:33 PM
puffsmokeonya's Avatar
wheel bearing could be bad on the front also.
Old Jul 15, 2009 | 10:45 PM
gradyc's Avatar
good to know you found the problem
Old Jul 23, 2009 | 05:13 PM
wildbill's Avatar
Good deal. Going to close the thread.
weatherby
Aug 31, 2015 08:04 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
ValleyF250
Nov 1, 2014 07:56 PM
