air leak
Old Jul 11, 2009 | 12:03 AM
jrad989's Avatar
Default air leak
when my turbo is engaged there is a really high pitched loud air leak from soewhere. no im npt stupid i know turbos make noise but this is even louder then my truck or my speakers all the way up. i mean its LOUD. is this leak from like a cracked hose or my actual turbo? suggestions or things to look for please. modified cummins with stock turbo. whats leaking air?
Old Jul 11, 2009 | 12:14 AM
coyropin's Avatar
yeah check your boost boots make sure you clamps are tight and there are no holes in them if you dont find any holes you might need to hook shop air and air it up to see
oh and
Old Jul 11, 2009 | 01:01 AM
jrad989's Avatar
boost boots where? im no diesel genious just so you know. learnin.
Old Jul 11, 2009 | 01:09 AM
coyropin's Avatar
no problem, they connect your pipes together you will have pipe then a rubber boot then pipe again check them out and see if the rubber has a hole or the clamp is loose check both sides there under your truck next to the wheel wells
Old Jul 11, 2009 | 01:31 AM
jrad989's Avatar
leave a helpfull comment leveled
oh thanks coyropin bye the way
Old Jul 11, 2009 | 03:01 AM
Uncle Bubba's Avatar
Scan through this thread and see if it helps. https://www.dieselbombers.com/cummin...tructions.html
ctjkelley
Jun 3, 2015 06:01 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
petew
Oct 25, 2014 09:29 PM
