LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
LMM mods for mileage
Old Jul 9, 2009 | 10:17 PM
GRI's Avatar
GRI
Default LMM mods for mileage
got a buddy who just wants to get some mileage gains. can he get a module for this or does he need a programmer. Can he install an airfilter kit without getting codes?
thx
Old Jul 9, 2009 | 10:26 PM
2500HeavyDuty's Avatar
dpf back exaust, air filter kit should be fine, he just needs to get a good one, and they are really expensinve
Old Jul 10, 2009 | 07:47 AM
GRI's Avatar
GRI
so he would see no mileage gains with just a module or programmer?
Are the air intakes a bolt on without codes?
any recomendations on exhaust, intake?
Old Jul 10, 2009 | 04:13 PM
Tanc Crusher's Avatar
Banks system with their dpf back setup, air intake, and 6 gun system claim maybe 2mpg improvement. Check out or call Banks on that. Anything else like a turboback system with a programmer will most likely cause warranty lose. On the LMM the ECM records that the tune has been changed and a new CVN number. If the numbers don't match what stock calibrations can be then they now it has had a non stock tune. It records the last 10 different tunes.
S&B seems to be the best not to throw the P0101 dtc code. Mass Air Flow sensor MAF. But stock airbox good for 500HP as I hear.
To improve mileage you will need to alter ECM tune and get rid of the DPF filter on the Exhaust and DOC. Then go turboback and use Edge Evo Race, PPE ++2 Hot Race, or Quad with DPF delete tune to get rid of the DPF regen. The ultimate programmer is EFILive but it comes with no tunes. But from some vendors and get a tune or 2 free. I went with Nick at DURAMAXTUNER.COM | Custom EFILive Tunes for Duramax powered GM Vehicles . Got 2 tunes from him with purchase. Other than EFILive I think the Edge unit is the only one that gets rid of turbo hiss.
I do the PPE air box mod. No cost to do. Goto PPE website and get instructions.
As to improved mileage it all depends on the tune and the engine. Let me put it this way. One may get better mileage with a 40HP tune and another guy may get worst on the same tune. Even if exactly the same and driven side by side. Now the guy with bad mileage may get great mileage on 90HP tune and the other guy who had good mileage on 40HP goes to a 90HP tune and his mileage may get worst. This trucks rolling off the lot can average 13mpg to 20mpg even if they are the exact same setup and driven exactly the same way. One never knows.
Brian
Old Jul 10, 2009 | 05:08 PM
tuning will increase the mileage, but if the tuner increases the ammout of soot put out by the engine it will clog up the dpf faster forcing it into regen more often, and there goes your mileage
Old Jul 10, 2009 | 08:49 PM
TCU Fan's Avatar
Aaron
I have the air intake and a PPE, with both of them I get about 15.2 MPG (now that I have 40k miles) daily driving on the highest setting. For the past month I have not had any HP increase on my PPE and have seen my economy go down to 13.2.
I drive a lot in stop and go traffic and rarely over 65 on the highway.
Old Jul 13, 2009 | 09:13 AM
GRI's Avatar
GRI
can I remove the DPF filter and get a quad programmer and be good to go?
My buddy would like to reinstall the DPF when he goes back to the dealer.
which one is the dpf? I saw a muffler and then 2 cans (one I am assuming is a resonator) is one of those the DPF? could I cut it out and instal a flex pipe and then reinstall it with band clamps when it goes back to the dealer?
Old Jul 13, 2009 | 10:23 AM
Tyler@MPF's Avatar
I would get a turbo-back exhaust. That way you dont do any damage to your factory exhaust. Then add the Quad like you said.
Make sure when you remove the factory exhaust you do not damage it, so you cn return it back to stock easily.
If you have any questions let me know.
Tyler
MPF
Old Jul 13, 2009 | 01:21 PM
GRI's Avatar
GRI
what would get damaged? the guy isnt going to be running any of the high powered smoke tunes so it should be fine.
I looked at the exhaust. Not sure there would be an "easy way to keep it in tact where it could be reinstalled "easily".
Old Jul 14, 2009 | 01:59 PM
Tyler@MPF's Avatar
If you cut the exhaust to get it off, I consider that damaging it. Just remove the exhaust in its sections and it will be fine.
