Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
using vegetable oil as fuel
Old Jul 1, 2009 | 11:22 AM
birty1's Avatar
Default using vegetable oil as fuel
Hi Guys,
I’ve read a lot on the forum about diesels running on used vegetable oil, it might sound scary but if it’s done right it can half your diesel costs which is a massive saving over the year. I found this helpful
www.howtofiltervegoil.co.uk
It tells you how to do it but more importantly what NOT to do and where to get all the bits from as well. I’ve been running mine on used oil for 18 months now and its ace.
I recon the engines smoother but that’s properly just me?
Old Jul 1, 2009 | 06:37 PM
Whit's Avatar
Site Mascot
give us some better detail on how it works for you and what all you had to do to the vehicle to accomidate the alternative fuel source
Old Jul 2, 2009 | 06:32 PM
solarwarp's Avatar
I don't think we have diesel Land Rovers in the USA. Is yours a Discovery? What year?
Tell us more about your rig? We like pictures too...
Old Jul 2, 2009 | 10:07 PM
wildbill's Avatar
Me thinks it's spam cause the URL takes you to a paypal link.
Old Jul 3, 2009 | 12:36 PM
DeLuzGN's Avatar
ditto
Old Jul 25, 2009 | 06:45 AM
veggyoilkid's Avatar
Default just that simple.... (:
I know of several mid 90's to early 2000 diesel's of several brands that have been running for years of very simple WVO blends.
The simple blend here is the most cautious and fool proof. >>>
During "summer conditions" you can easily run the following:
1.5g Gas / 3g #2 / 7.5g WVO
I know the gas scares people...Hey don't bother
Here in northern Michigan, we run the mix without gas at all depending on the temperature.
Usually July / August.
The point is ....it works
If you are interested but don't want to experience any chance of problems, back off on the gas or eliminate it completely and just add some filtered oil when you fill up.
Try this experiment....I do this all the time
Do a test sample. Say 50% WVO/50% #2 diesel.... in a clear peanut butter jar (that has been cleaned of course!).. Set it outside and look at it in a couple of days...
Likely it will not begin to show signs of separation until the temp gets down say...30-40deg.
The biggest trick is starting on the fuel, once up and running it works real well. So go easy on it and you will be impressed how well it works.
*** Do not however try this on a newer high pressure fuel system ***
03 and older Power stroke - 12v Cummins work well have fun
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
bigredcummins
Jan 4, 2015 04:37 PM
