shutter at take off
Old Jun 29, 2009 | 09:28 PM
murrayg's Avatar
Default shutter at take off
My 2000 crew cab 7.3 4*4 has a bit of a shutter at take off once in a while, I would guess it has something to do with the trany or torque convertor but the tranny perfoms well. Could it have something to do with the disc brakes or the rear end.
murray
Old Jun 29, 2009 | 09:36 PM
CSIPSD's Avatar
It could be a few differant things, but my first guess is a bit of a loose tranny. Is it only when loaded or all the time? If it does it when you are braking then it could be rotors, but if not its tranny related.
Old Jun 29, 2009 | 09:41 PM
murrayg's Avatar
it is only when I start off once in a while, I think it might br the rotor but that might be wishfull thinking. I have not noticed any slipage in the tranny loaded or unloaded.
thanks for your input
murrayg
Old Jun 29, 2009 | 09:43 PM
powerstroker52's Avatar
could it be worn out U-joint, i know my truck lunged or seemed like it slammed alittle on take off when mine were bad.
Old Jun 29, 2009 | 09:52 PM
murrayg's Avatar
if the posi was going would it shutter? U joints are good
murray
Old Feb 27, 2011 | 09:03 PM
murrayg's Avatar
I changed the rear end fluid with the non slip (stink fluid) and the shudder went away.
Old Mar 3, 2011 | 07:25 PM
jshblain's Avatar
if you have a 2 peice drive shaft, its most likely the carrier bearing that supports the drive shaft, mine was doing the same thing. comeing from a stop light taking off it would shudder especailly when i got on it. doubtfully a rotor. unless its so bad its grabbing while driving, but im sure you would notice that alot more. an a rear end shutter, maybe, but you would feel that more on cornering. hope this helps.
