12V vacuum location?
Old Jun 27, 2009 | 02:21 PM
woodly1069's Avatar
Default 12V vacuum location?
Well I just got in my new Autometer pillar set and they are NICE! I was wondering if anyone had a good location to pull vacuum from. I tried up top to the diaphram on the inside drivers fender and nothing. Since this thing isn't full of vacuum lines like my old gassers I'm a little confused about where to get the best signal. I have a 60 PSI gauge; what should I be getting when I mash it anyways; 20? Since we are on the subject I will need to install the pyrometer as well and there is some discussion about the best place for that as well. As usual, any input is appreciated.
Old Jun 27, 2009 | 07:33 PM
Why are you measuring Vacume?
Are you talking about turbo boost?
Boost:
Pyrometer (Pre-turbo is much better than post-turbo):
Old Jun 27, 2009 | 08:19 PM
JKM's Avatar
JKM
I'm with doc, there is no vacuum on a diesel engine as there is no restriction in the intake. There is however a vacuum pump on the engine that supplies vacuum for the brake booster , cab vents, 4x4 actuator, and cruise control, but this does not need to be monitored.
Old Jun 30, 2009 | 12:10 AM
davo79's Avatar
My 95 has no vacum pump it pulls the vacum off the side of the block just below the fuel pump so to say a diesel has no vaccum is crap all engines create vaccum somehwere the only time you would need to measure vaccum is if you have a vaccum opperated exhaust break. And that is only so you can make sure there is enough vaccum to operate it
Old Jun 30, 2009 | 12:11 AM
94cummins12v's Avatar
that is the vacuum pump
Old Jun 30, 2009 | 03:07 AM
davo79's Avatar
Yeah if you're calling the whole engine a vaccum pump I suppose it is but unlike the 24valve motors there is no electric vaccum pump on the engine
Aug 13, 2015 10:10 AM
cutthroatxxx
Mar 13, 2015 08:41 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
casper83
Jan 21, 2015 09:36 PM
Nov 7, 2014 05:40 PM
