any one know about 4 k gov kit?
Old Jun 26, 2009 | 04:11 PM
bowtech's Avatar
Default any one know about 4 k gov kit?
i have the 4k kit but dont have the valve springs. i have 2 questioned i wood like to no be for i do it. first one is with it installed 3 or 4 k part if i floor it from a stop will it shift before it red lines? second is will it mess a up a stock tranni? im goin to buy a valve body soon just not sure wat to do. a 3k or the 4k
Old Jun 26, 2009 | 07:23 PM
djwhonda92's Avatar
just get the 4k... it will shift before redline... but if you drive normal there is no difference... thats why i love it.. when you floor it the difference is amazing.. go with the 4... i know it isnt good for a stock tranny but i know that a 3k isnt either
Old Jun 26, 2009 | 10:08 PM
bowtech's Avatar
OK THANKS. it dont run hotter does it?
Old Jun 27, 2009 | 07:41 AM
LOGANSTANFORTH's Avatar
i would suggest valve springs, you float them once and kiss your engine good bye......
Old Jun 27, 2009 | 08:00 AM
relay93's Avatar
Adding more fuel as in bigger injectors, different fuel plate, your foot controlling the throttle with the 2 previous items installed and using stock charger will determine how hot it gets.
Go back to this post that you started.https://www.dieselbombers.com/5-9l-1...springkit.html
You will see most guys suggested to you to install 60lb valve springs if you want to install the 4k gov springs. If you want to install the 4k springs with out the insurance of the 60 lb valve springs then you are the one who will have to pay close attention to the tach. Just like with adding more fuel you can add injectors different plate but you are the one that has to pay close attention to egt's and to know to let off the skinny pedal.
Good luck on your decision.
Old Jun 27, 2009 | 10:31 AM
bowtech's Avatar
i think im only goin for the 3k i will have the springs for the 4 when i have the money for the 60ln springs
Old Jun 27, 2009 | 11:54 AM
relay93's Avatar
Thats what I did. Install the 3k and when I replace the valve springs I will then Install the smallest spring to complete the 4k setup.
IMO you have made a wise choice.
Good luck.
Old Jun 27, 2009 | 04:20 PM
bowtech's Avatar
nm think the whole kit goin in that way i will acutally have it done bc if i dont i will just leave it like that and give me the moetom to get the 60lb springs
Old Jun 27, 2009 | 07:15 PM
Dynomite Diesel 3K kit includes both the 3K springs and 4k Springs.
Old Jun 27, 2009 | 09:34 PM
bowtech's Avatar
yeah the kit i have is for the 3 or 4
