6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Arp Headstuds
Old Jun 24, 2009 | 03:14 PM
DieselSlug's Avatar
Default Arp Headstuds
Does anyone know where i can get arp headstuds for the 6.5 at a decent price. The cheapest i have seen is 159.99 on summits page?
Never mind, i found the price quote thread section, this is cool!!
Last edited by DieselSlug; Jun 24, 2009 at 03:14 PM. Reason: Automerged Doublepost
Old Jun 25, 2009 | 01:35 PM
Woody35's Avatar
welcome i didnt know you were over here. hows the starter?
Old Jun 25, 2009 | 04:11 PM
DieselSlug's Avatar
Just joined the other day. Cool site!! I think the starter is ok, but i will not no till i install the ignition switch, ignition tumbler lock, and ignition alarm switch, and then for safety two battery cutoffs, so if it happens again i will just unscrew them, it wont be done for prolly another week, i wont get the parts till next thursday...
Old Jun 25, 2009 | 04:17 PM
Woody35's Avatar
well i hope it all works out good. and driving a 302 mustang to work cant be that bad either for the time being
Old Jun 25, 2009 | 09:27 PM
Turbine Doc's Avatar
inexpensive & ARP in same sentence you gotta be kidding right
Old Jun 25, 2009 | 11:02 PM
DieselSlug's Avatar
Note: i didnt say inexpensive, i said decent..
I know you get what ya pay for, i was just seeing if i could get a set for a little chreaper going with a site vendor....
Old Jun 26, 2009 | 03:58 AM
LOGANSTANFORTH's Avatar
160 bucks for ARP head studs for any engine is friggin cheap, are you sure those aint main studs......cause thats insane cheap......
Old Jun 26, 2009 | 05:55 AM
DieselSlug's Avatar
I really dont know what cheap is for them, i have never gone shopping for headstuds before, ive always used bolts... I found another place that sells them for 260... The summit site says they are for the 6.2 but i think they are the same....
Old Jun 26, 2009 | 11:25 AM
Woody35's Avatar
im pretty sure there headstuds. the most boost a 6.5 will probably see is 25 Psi in a heavely modified engine so its a bit shy of the current high performance diesels. dont need as much clamping force
Old Jun 29, 2009 | 12:22 AM
OEM studs are fine at stock boost levels and a engine with a healthy cooling system, unless you expect to run 15+ consistently or do a lot of head gasket changes really no need to swap to ARPs
