Pyrometer problems
Old Jun 18, 2007 | 10:08 PM
rolloffhill's Avatar
Default Pyrometer problems
I bought a set of autometer cobalts from a member at another site. Well they sat around for a while, and last week I wrangled up all the parts I needed for the install.
I currently have Banks dynafact gauges, and eventually the Banks will get phased out when I get my tranny done.
Well, the Banks pyro is tapped in the manifold and the tap is bigger than the autometer pryo. Well just so happens I had an extra Banks pryo and pyro lead laying around. So I connected 2 leads from the pyro, one still goes to the 6 gun, the other I used to hook up to the new(used) cobalts. Well now for the question.
Leads are just wires right, it doesn't matter whether they are cut and spliced correct? I didn't have any luck soldering them, but when I hooked them up to the existing pryo and spliced them into the autometer harness the gauge did nadda.
So I spliced the original autometer pyro back to the autometer harness and put the propane torch to it. Still nothing.
So the question is, it should work if it is hooked up no matter what right? I mean both harnesses had yellow and red wires. So is it just the gauge that crapped out on me? Or am I just an idiot and ed up the harness?
Old Jun 18, 2007 | 10:15 PM
Lostnwalmart's Avatar
i have always hear that pyro's are very picky about splices or soderig but dont knwo much more than that.
Old Jun 18, 2007 | 10:18 PM
Uncle Bubba's Avatar
Your screwed. If you read the directions they should tell you specifically not to solder and the guages are calibrated to the wire lengths they are shipped with. I can't tell you why, just that the instructions always say this.
Old Jun 18, 2007 | 10:19 PM
If you need a different size to fit in the stock hole you have just go to the home supply store and pick out what you need in the plumbing supply. Just Brass compression fittings.
Old Jun 18, 2007 | 10:21 PM
AH hell I didn't get any directions with them. Didn't think it would matter,
Next onto the probe, is the brass gonna hold up to the heat? The bushing that the banks came with isn't brass, and the autometer probe isn't brass either.
Old Jun 19, 2007 | 01:57 AM
Your gonna melt the alluminum in your engine before you melt brass. My Autometer probe came with brass fittings, they were just the wrong size and I had to go through this same thing to make it work.
Old Jun 19, 2007 | 02:12 AM
DB Admin's Avatar
Banned
There are a bunch of different types of thermocouples
http://www.facstaff.bucknell.edu/mas...pThermCpl.html
DM
Old Jun 19, 2007 | 02:17 AM
DM
Ok I read it. Does it say his Pyro will or won't work.
Old Jun 19, 2007 | 02:31 AM
Logan's Avatar
I have had no issues with my brass. My brass is good.
Old Jun 19, 2007 | 02:53 AM
DB Admin's Avatar
Banned
I dont see where Shorting the wires would affect it
DM
