03 5.9 injector install
are you talking about the wire that hook to the injectors??? I dont think you want to switch them around might throw off the firing order...really in these cases the wires should just be long enough to reach the injector there supposed to be hooked to. Dont know for sure though because ive never really seen under neath a valve cover of CR
They could possibly be switched, then that injector would not work properly, if even at all. When you put the gasket back on it is easy to tell which wire goes where, or at least it was for my 06. I am sure someone on here will chime in with a pic to show you how to wire them up, I know that the 06 harness is different from teh 03 or I would go out and take a pic for ya.
Hmfman91
8
Jul 3, 2015 05:52 PM
