Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
best way to get out light scatchs?
Old Jun 17, 2009 | 08:28 AM
pullenplowen's Avatar
Question best way to get out light scatchs?
did some 4 wheeling with my grandson and pick up a bunch of light scatchs from branchs in the woods. what is the best way to get rid of them. eveyone says they will rub out. what should i use and whats the best way to do it. by hand or ? ? ?
Old Jun 17, 2009 | 08:44 AM
So are these marks or actual scratches? Hard to say if it will work without actually seeing it. I would try 3M Rubbing Compound. Its under $8 at Walmart:
http://solutions.3m.com/wps/portal/3...bing_Compound/
If you get it at a professional autobody supplier you can get different cuts that take out deeper scratches.
Yes, you can do this by hand, which may take some persistance. Think I would stay away from the power polisher since you can do some damage with it, if you dont know exactly what youre doing.
Depending how deep the scratches are - you may have to get some 2000 grit and wetsand it - followed by the rubbing compound and then some good wax.
Old Jun 17, 2009 | 09:22 AM
BEERPLAY's Avatar
Originally Posted by Dr. Evil
So are these marks or actual scratches? Hard to say if it will work witout actually seeing it. I would try 3M Rubbing Compound. Its under $8 at Walmart.
Yes, you can do this by hand, which may take some persistance. Think I would stay away from the power polisher since you can do some damage with it.
I AGREE ALSO I HAVE A BOTTLE OF MOTHERS SCRATCH REMOVER IT WORKS PRETTY GOOD ON SMALL NOT DEEP SCRATCHES GOOD LUCK
Old Jun 17, 2009 | 10:16 PM
midnite><og's Avatar
turtle wax liquid clay bar, scratch remover.. good 3 stage wax by mothers...
Old Jun 17, 2009 | 10:32 PM
stkdram55's Avatar
sharpie??
Old Jul 16, 2009 | 10:46 AM
DuramaxDiesel02's Avatar
Originally Posted by stkdram55
sharpie??
Old Jul 17, 2009 | 06:39 PM
BIGBILL105 45's Avatar
wool buffing pad and some 3m buffing compound should do the trick if they aren't too bad.
Old Jul 17, 2009 | 07:31 PM
01superduty89's Avatar
sand paper could help?......jk mothers works good
Old Jul 23, 2009 | 10:03 AM
Worked For me
Old Aug 10, 2009 | 12:59 AM
97dirtydozen's Avatar
Light scratches..2000 sand paper (wet)..3M or P&S compound..if u have a buffer and know how to use it, great..if not u can rub 2000 scratches out by hand..but follow with some sort of polish to remove compound scratches..again 3M or P&S. You can usually get the compound and polish from a local auto paint store. Also for deeper scratches..you will be able to get away with 1000 grit on factory paint..just be very careful..kinda have to know what you are doing..then follow with 2000 grit (all wet of course) then compound and polish..and a good coat of wax..hope this helps..
