Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
White field boss 32 making oil.
Old Jun 14, 2009 | 10:12 PM
7.3 Cowboy's Avatar
Default White field boss 32 making oil.
My nieghbor has a White field boss 32 and it has made a gallon of oil since his last oil change. I think it has to be something with the injectors. What do you yall think?
Old Jun 15, 2009 | 12:15 AM
Uncle Bubba's Avatar
Gas, Diesel, Fuel injected. Just had this problem with my Massey and it turned out to be a bad Lift Pump leakin fuel into the crankcase.
Old Jun 15, 2009 | 12:19 AM
SEA04DMAX filled me in on how to tell if it's oil or hydraulic fluid here in my post. He said
If you put a drop of engine oil on a napkin , if it has fuel in it it will wick out ward pretty quick.
Worked for me, helped me diagnose my problem. Also check the power steering and hydraulic fluid to see if either of them is low.
Old Jun 15, 2009 | 11:15 AM
7.3 Cowboy's Avatar
It is a (pretty sure) non-turbo diesel. Ill have to try that napkin trick.
Old Jun 16, 2009 | 12:16 PM
Did ya have any luck on this yet or are ya still tryin to swim yer way out of the flood water.
Old Jun 17, 2009 | 07:18 PM
7.3 Cowboy's Avatar
well honestly i have been to busy and have not tried it
mattshow123
14
Mar 12, 2018 01:41 PM
Durtyd09
Nov 11, 2015 01:43 PM
soco
Jul 27, 2015 06:06 PM
markv8993
Jun 21, 2015 12:24 AM
Oltian.
Diesel Bombers Sponsors
Feb 24, 2015 10:07 PM
