99' F350 won't start after sitting for 12hrs.,what is causing this?
Old Jun 10, 2009 | 03:46 PM
StickyBooger5's Avatar
Default 99' F350 won't start after sitting for 12hrs.,what is causing this?
*PLEASE HELP* I have just bought my first diesel. I have a 99 Ford F350 Crew Cab 4x4 8"lift. The issue I am having- if the truck sits for a day or so without running, it will not start. I turn the key, and wait for the "wait to start" light to go off after 7seconds and will crank over but not start. Here is the kicker: if i turn the key and wait for the "wait to start" light to go off, then turn the key off, and repeat this process at least 4 times. On the fifth time the truck will fire right up. It is like I am having to prime the fuel pump or something. When the truck is running, I dont have any issues. I can turn the truck off and on all day and it will fire back up. This only occurs if it sits for more than 12hrs. without running. I am under the assumption that if the fuel pump was bad, it wouldnt run at all. Dont those just completely quit working? I dont have any leaking fuel, nor can I smell a fuel leak. I have replaced the glow plug module this past monday. I replaced the cam position sensor this morning. Has anyone ever heard or experienced this issue? Thanks for any help that can be offered.
Old Jun 10, 2009 | 03:50 PM
DB Admin's Avatar
Banned
you could be losing prime by having a leaking fuel line ? Is it leaking any fuel ?
Old Jun 10, 2009 | 03:52 PM
No, I dont have any visable fuel leak nor do I smell any fuel. thanks.
Old Jun 10, 2009 | 05:26 PM
Begle1's Avatar
It could be a leak in fuel return for the injectors, or for the fuel pump or anywhere else there is a return on your HEUI system. Leaky returns aren't visible and chasing them is like snipe hunting.
That explanation only works if you have an electric lift pump that runs for a little bit on start-up? A lot of Cummins do, I don't know if your HEUI does. If not, it sounds like an electrical problem.
Old Apr 28, 2012 | 01:59 AM
Eric Jess Ruther's Avatar
Default same problem
hi I have a F550 that does the very same thing did you ever figire out what is was I had a diesel mechanic tell me yesterday that it is the o-rings on the injectors doesn't sound right to me considering when you plug the block heater in it will start no problem I also had new injectors put in and the control unit any ideas would be helpfull
Thanks
Eric
Old Apr 29, 2012 | 05:28 PM
roaddog51's Avatar
I woud say from past experience that you have a air leak some where. either on the low side (from tank to pump) or high side (injector pump to injectors) this is whats causing fuel presure to blead off, thats why you have to crank the crap out of it ,so it will build presure back up to start... hope this will give you somewhere to look...
Old May 7, 2012 | 09:34 PM
MonsterStroke's Avatar
Plug the truck in one nite. if it starts right up could be grow plugs not warm up the engine. had same problem in my truck,
Old May 7, 2012 | 10:37 PM
articfox's Avatar
sounds like glow plugs. glow plugs warm up the block try this if you have a block heater plug your truck up over night then see if it cranks if it does then it sounds like glow plugs glow plugs are not to bad to replace and in price give it a shot. id allso check the fuel filter ive herd of this happening before and the guy had a dirty fuel filter wouldn't let it crank on the first few times then it would finally crank after it got enough fuel in the motor.
Cavnar
Sep 9, 2015 07:18 PM
ronstop
Feb 26, 2015 09:48 AM
shawnecarter
Jan 11, 2015 03:19 PM
shawnecarter
Jan 7, 2015 05:54 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
