home made 3000 gsk
Old Jun 4, 2009 | 10:19 AM
BAD ASS RAM's Avatar
Default home made 3000 gsk
i was wondering if anybody knew where i could get the specs on the 3000 gsk,such as spring rating,length,and diamater,and the spacer/seat?dimensions.i work in a machine shop so i can make just abouy anything.and i have acsess to all kinds of springs.probably a long shot but i thought i'd try.i could prob make and sell them for about 50-75 dollars.
Old Jun 4, 2009 | 11:03 AM
FastCR's Avatar
There might be an easier way for you. Many people shim their stock springs with a modified washer. Its some weird size and you still have to grind it down to size. I think you might be better off making those shims in the correct size. Every pump is different, but I believe it will raise it to between 3000 and 3200 rpm. Someone who's done it can probably give more info.
Old Jun 4, 2009 | 12:58 PM
do you have any idea how much they shim them?if tha tis the case,all i have to do is pull the factory one out and measure it,then add the proper amount and make a new one.
Old Jun 4, 2009 | 02:26 PM
FastCR's Avatar
I'll have to see if I still have the links bookmarked somewhere, if not I'll look around compD and cummins forum and you can too I know there are enough people that have done it.
FINALLY here it is
http://www.dieseltruckresource.com/d...7.html?t=93017
Old Jun 4, 2009 | 02:48 PM
Cummins97's Avatar
I didn't have a good experience with the standard washers but the metric version worked perfectly. Here it is - Shim your governor springs - Competition Diesel.Com - Bringing The BEST Together
Old Jun 4, 2009 | 02:59 PM
FastCR's Avatar
ahhhh thanks I was searching for almost an hour and couldn't find that one.
Old Jun 4, 2009 | 03:25 PM
how many rpm's did you get out of it?
he yman i really appreciate it,most would look one time and if they didn't see it at first that would be it,thanks for the effort,i'm fixin to do this tonight,i've got a pull comin up in a couple weeks,i want to be the best with what i got.
Last edited by BAD ASS RAM; Jun 4, 2009 at 03:25 PM. Reason: Automerged Doublepost
Old Jun 4, 2009 | 03:48 PM
bowtech's Avatar
if it works out good let me no ill buy one from you
Old Jun 5, 2009 | 01:05 AM
I wouldnt recommend this unless you know exactly what your doing.
Old Jun 5, 2009 | 01:56 AM
94cummins12v's Avatar
x2 thats why they designed the kits for us doit yourselfers
autostroker
Jul 4, 2015 10:39 AM
