adding boost valve with tuner?
Old May 31, 2009 | 08:11 PM
REDRIDE13's Avatar
Default adding boost valve with tuner?
Anybody Know what type of boost numbers I may be runnig with a hypertech tuner? I was going to buy the PPE bost valve but dont want to over boost the stock turbo?
Old May 31, 2009 | 08:13 PM
FastCR's Avatar
Pick up some gauges ASAP!!!
Old May 31, 2009 | 11:45 PM
2500HeavyDuty's Avatar
you should be fine with the hypertech n boost valve
Old Jun 1, 2009 | 04:37 AM
Big_Johnson's Avatar
i'm runnin a PPE standard with the PPE boost valve and i usually have it at a 220hp tune and i haven't seen over 28psi. except once and that was goin uphill at 70 and i hit 29 for a split second. normally i'll hit 25psi tops. so you should be perfectly fine. But yes listen to FastCR, GET GAUGES!
Old Jun 3, 2009 | 01:48 PM
REDRIDE13's Avatar
Well I am, planning on getting a boost/egt gauges any idea where I could get some good info on a install?
Old Jun 3, 2009 | 04:20 PM
Ask Danny. That's what i always do.
Old Jun 3, 2009 | 08:17 PM
ima have to start charging per text for consulting with me
Old Jun 4, 2009 | 07:56 AM
REDRIDE13's Avatar
LOL Thats why I come here for free advice! Seriously though how tough of a install am i looking at. there is no way I am drilling into my turbo! wOULD it be ok if I put the sensor in the turbo down pipe? Right after the turbo?
Old Jun 4, 2009 | 08:26 PM
boost valve takes maybe like 30 seconds to install.
you cut the rubber hose in the front of the turbo that goes to the waste gate in half and pop that valve in and hose clamp it on
Old Jun 5, 2009 | 12:15 PM
REDRIDE13's Avatar
what type of hp gains are typical?
