Desperate in need, 02 Dodge 5.9, 6 spd.
Old May 30, 2009 | 10:02 PM
dochawken's Avatar
Default Desperate in need, 02 Dodge 5.9, 6 spd.
5.9 Cummins, 02 dually...have had no acceleration for 10 weeks, stranded in the Sierras with questionable geniuses ripping me off...so far 3 K....They have done the following:
1) new PCM
2) reman. ECM
3) new MAP sesnor
4) new IAT sensor
5) new fuel filter
plus ungodly labor charges...
error codes have remained same
P PCM
P ECM
P 0237
P 0112
P 1693
truck has 210K miles
So I'm really in a tough position..need to get back to Tennessee. I'm begging
Old May 30, 2009 | 10:06 PM
FastCR's Avatar
what area ya stuck in?
Hopefully we can at least point you to an honest shop.
Old May 30, 2009 | 10:26 PM
dochawken's Avatar
Tonopah NV
Old May 30, 2009 | 11:42 PM
Sorry to hear about your trouble - I think we will at least be able to point you in the right direction.
P0237 = Turbocharger Boost Sensor A Circuit Low
P0112 = Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P1693 is a companion code that just essentially means that another code has been set
Do you happen to have guages installed? A boost guage would probably hep with troubleshooting this.
Since they already replaced the IAT sensor - is it possible that they didnt clear the codes? I would assume this is at a Dodge dealer...
Old May 31, 2009 | 07:47 AM
dochawken's Avatar
yes..sadly it is Dodge....the place that ripped me off went bankrupt last Thursday. After the PCM and ECM were installed I get not only a check engine light but also ABS and parking break light.....they just scratched their heads!!
Old May 31, 2009 | 01:34 PM
FastCR's Avatar
maybe I'm way off buit at that point I'd start tearing through grounds....
Old Jun 1, 2009 | 04:23 AM
coyropin's Avatar
I or we at are shop had a 2001 dodge kinda same problems it was the vp44 but it had a timing code it started and ran good till you gave it some rpm, I dont know if this will help
Old Jun 1, 2009 | 10:48 AM
Make sure they clear all the code. It could be a bad connection on the IAT Temp or a Bad Sensor. I have seen them bad out of the box.
Old Jun 1, 2009 | 01:28 PM
AABEAR's Avatar
Check all ground wires and load test your batteries sound like low votage or bad ground.
Old Jun 1, 2009 | 07:15 PM
vlado's Avatar
i hope you didnt pay for all the stuff they did on your truck. if you paid with cc or check i would cancel asap.if they missdiagnose problem it is not your fault.
