Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
fuel and additive question
Old May 23, 2009 | 10:55 AM
usmc_0331's Avatar
Default fuel and additive question
Whats your guys thoughts on AMSOIL Cetane Boost Diesel Fuel Additive? Also I'm on a base wih acess to jp8 could I run that in my cummins?
Old May 23, 2009 | 04:36 PM
Heath's Avatar
Authorized Amsoil Dealer
I use it
I just heard a presentation on a survey done of diesel fuels across Amercia. The one thing you can count on is no two stations are the same. The fuels vary quite a bit in quality. Today's hwy fuel is the ULSD which requires 15ppm or less of sulfur in the fuel. On average, they are actually 1-2ppm. This is very low for lubricity. Now on the flip side, many stations now have some percentage of biodiesel which adds some of that lubricity back.
It's hard to tell who has biodiesel and who doesn't. It's not required to be marked on the tank for 5% or less. From 6-20%, it just has to say it contains bio but does not have to say percentage. Anything over 20 will be labeled as such.
Cetane levels also vary quite a bit. 40 is the lower limit all fuels are suppose to meet, but this survey found it can range from 40-60 at various pumps. 50 is the desirable level for most efficent burning.
All this variation makes a good case for treating the fuel we put in our tanks. I use it in every tank along with the diesel concentrate and I try to buy from the same station as much as possible so I have some consistancy.
If interested in the amsoil products and don't have a source, we can get it to you at wholesale.
Sorry I went a little beyond your question, I was on a role.
Heath
Mike0624
Jul 17, 2015 09:39 AM
J. Nick
Apr 25, 2015 05:01 PM
jds94_6.5td
Mar 18, 2015 12:02 PM
That boy GK
10
Oct 28, 2014 01:45 PM
Omingnome
Oct 20, 2014 12:25 PM
