Can't Find That Annoying Oil Leak
Old Jun 13, 2007 | 02:37 PM
bigcountrysg's Avatar
Default Can't Find That Annoying Oil Leak
Well do you have a minor oil leak. That you can not find. Well on the passenger side of the engine near the firewall. There is a brass fitting ontop of the valve cover this is a plug for the HPOP system. Well there is an O-ring that seals that brass fitting. You need a 5/8 wrench to remove that fitting. Then if the O-ring doesn't come out with the fitting a small flat head screwdriver will get it out. Then you replace that damaged o-ring with a new one. Put a little motor oil on the O-ring so it will not get cut during install. Then reinstall that brass fitting.
I had an oil leak for 3 months that I could not find. I knew it was coming from the top of the engine. Well I found it being that 2 dollar o-ring.
Old Jun 13, 2007 | 06:31 PM
TEXASPOWER's Avatar
ive never changed one but the ford house did on my 02 about 20 times, along wilots of other crap , i tried looking the first time for about a weak and said forget it, great info though wish u would have posted this about 3 years ago
Old Apr 9, 2008 | 02:48 PM
RTL Garage's Avatar
Was That The Fix For Good? Or Did It End Up Coming back?
cummins Pride
Sep 28, 2015 12:11 PM
Sootboyz89
Jun 28, 2015 02:31 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
