DIY Map Fooler
Old Jun 13, 2007 | 02:32 PM
bigcountrysg's Avatar
Default DIY Map Fooler
Ok if your running a chip and exceeding your maximum boost allowed for your truck. I bet your check engine light comes on ever so often. Usually when it does it is from the map sensor. I bet when you let off and drive easy for a couple miles the light goes back off on its own too. Well then you need a map fooler.
This is what you need Air Pressure Regulator. Home depot sells them cost is 12 bucks. Then you need 4 hose clamps for 3/8 inch hose. You need two burr hose connectors to put on the regulator. Ok now what you do is set the regulator for 20psi. I used my air compressor for this. Then what you do is locate the Map sensor line which is a black rubber hose going to the map sensor. You can either cut that hose or you can get a short section of Pressure hose from the local parts store. Then you install the pressure regulator inline. Then your map sensor will no longer trip the pcm and cause a check engine light to come on. I been running like this for about 4 months with no problems.
Old Jun 20, 2007 | 08:22 AM
rolloffhill's Avatar
Nice to hear of easy DIY fixes
Keep them coming..
Old Jun 20, 2007 | 09:10 AM
Diesel Nut's Avatar
Nice writeup!
Old Dec 3, 2007 | 04:41 PM
sixpack1's Avatar
Can we get some pics of this set-up? Sounds easy enough, but pic help when purchasing the parts and pieces. Great write up!!! Sixpack
Old Dec 4, 2007 | 02:16 AM
2500HeavyDuty's Avatar
This Method sounds like it would work for a Dmax waste gate also i am going to have to try this out because i have gotten engine over boost codes before while running my quad on a high setting
Old Feb 25, 2008 | 12:58 PM
DA BUS's Avatar
Great idea!
|WYG|SS
Jul 26, 2015 11:18 AM
RexShoppe
Price Quote - Request A Price
Jun 16, 2015 02:48 PM
Jan 9, 2015 09:30 AM
somarillw
Dec 4, 2014 12:37 AM
Spiderman
Oct 6, 2014 04:37 PM
