Ignition Key Dinger
Old Jun 13, 2007 | 02:13 PM
bigcountrysg's Avatar
Default Ignition Key Dinger
Ok for all of you guys that want that annoying dinger gone. This is for you, It is very simple to disconnect that dinger.
What you do is, locate the black wire with a purple tracer on it. You have to remove the ignition and steering column cover. You will see a black wire with a purple tracer on it. Disconnect that wire that goes to the ignition switch. tape it up and make sure it is not going to touch the ignition switch. Then reassemble the steering column cover and reinstall the ignition switch. Now you can work on your truck with the doors open and the keys in the ignition with no dinger to annoy you.
Old Jun 13, 2007 | 02:20 PM
JON's Avatar
JON
Member
Default Hey BC
Its been a bit since I've been into one. Thats the wire that clips onto the top of the cyl hole right?
Old Jun 13, 2007 | 02:24 PM
mine was on the side, could be on the top. But I know on the 99-02 PSD's the wire is black with a purple tracer and it is all by itself.
Old Jun 13, 2007 | 02:28 PM
JON's Avatar
JON
Member
Default Yes
but if i'm not mistaken it was attached to a little plastic clip on the cyl hole right?
Old Jun 13, 2007 | 02:40 PM
Yes I believe your correct. I done this like a year ago I would have to go look at mine to remind myself.
Old Jun 13, 2007 | 02:52 PM
JON's Avatar
JON
Member
Default Ok good,
Thats the one I was thinking of. It is also a problem to brake off that plastic clip and cause your chim to activate with the door shut. But if you pay close attention the light on your dash isnt on so that tells you its the wire or clockspring and not the door ajar. So there are two potinial issues.
Mac1997
Jul 13, 2015 05:08 AM
david.burger
May 30, 2015 08:25 AM
Mar 13, 2015 09:20 AM
1997silverado
Feb 13, 2015 08:11 AM
Baradium
Nov 21, 2014 08:20 AM
