update on truck is dead
Old May 13, 2009 | 07:31 PM
stevescummins's Avatar
Default update on truck is dead
I took the starter off and had it checked and it is fine. Replaced starter relay. Still won't turn over. Shouldn't I have 12 volts to the relay all the time? I get 12 volts when the key is turned to the start position. If I run a jumper to the one turminal on the relay and then put the relay in with the wire hooked up I can get in the truck and it starts fine. I seems like I lost my 12 volts that continously feeds the starter relay. Anyone ever had this happen? I'm going to pull the relay panel loose so I can trace the wires on the relay and see where I'm looing power.
Old May 13, 2009 | 07:55 PM
coyropin's Avatar
there is a fuse its in your fuse panel under the hood you will have 12v to the relay all the time then when you turn your key you will have a 2nd power to the relay my starter was going bad and i had to replace it all the time till i got a new starter i will get you a pic here in a min
Old May 14, 2009 | 05:08 PM
Hey Coyropin you were right. That fuse is one of those square 20 anp ones. It was in a spot that said spare. I changed it and all is ok. Thanks for the help.
Old May 14, 2009 | 06:10 PM
coyropin's Avatar
any time
Old May 14, 2009 | 06:50 PM
Good job fellas. Closing this one as it appears fixed.
burndiesel
10
Feb 7, 2023 01:15 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
Sep 30, 2014 10:00 AM
