oil problem
Old May 11, 2009 | 08:13 PM
94cummins12v's Avatar
Default oil problem
ok this is to the point were its got me kinda worried but not to the very worried point. the past few days i notice above 1500rpm the oil pressure is a bit over 40psi, under 1500 rmp its center of the two hash marks. sometimes it flucktuates below the first hash mark. would this be a sign of a oil pump going out.
Old May 11, 2009 | 08:19 PM
Verify with a mechanical guage in the cab
Old May 11, 2009 | 08:20 PM
you mean buy another guage and stick it in the cab purmantly or just to see if its an issue?
Old May 11, 2009 | 08:23 PM
Either way you want.
I have a mechanical oil pressure guage in the cab but Im running S.S. braided hose.
Old May 11, 2009 | 08:24 PM
holy hell i dont think i can physically put another guage in my truck. got the piller full and a 3 pod on the dash i have a aftermarket fuel level guage because my factory one dint work no more
Old May 11, 2009 | 08:34 PM
well you could just tape a pressure guage to the windshield to verify oil pressure. Just a thought.
Old May 11, 2009 | 08:42 PM
well if i did that i would only want to use it to see if its my pump or not
would out of the oil housing like were the turbo supply line comes out, would that be an accurate place to hook it up or in the block were the factory sender is?
Last edited by 94cummins12v; May 11, 2009 at 08:42 PM. Reason: Automerged Doublepost
Old May 11, 2009 | 08:46 PM
angelic0-'s Avatar
didn't you just rebuild that engine?
why would more pressure be bad?
Old May 11, 2009 | 09:27 PM
Yes, remove the other plug (its 1/8' NPT) and hook up your hose right there on the filter head.
Heres a bad pic of mine:
Old May 12, 2009 | 08:18 PM
ya i just rebuilt the engine, i have a bypass fitler housing hooked to the other port on the filter head. it aint hooked up yet becasue im still in breaking. i might get a cheepy somewere just to throw in and look, has many people had problems with there electrical ones failing
ok i hooked up a mechanical guage to the oil filter housing and above 1400rpm and full throttle is about 70psi and on the instrament panel guage its a tad over 40psi. at idle when the panel guage fluctuates down the mechanical guage stays at about 35psi. when the mechanical is at 40psi the panel guage is way below 40psi. is there a differnce in pressur between were the electrical sender is and the turbo supply line?
Last edited by 94cummins12v; May 12, 2009 at 08:18 PM. Reason: Automerged Doublepost
