help! lost power, loud knock, etc.
Old May 9, 2009 | 02:01 PM
Xero's Avatar
Default help! lost power, loud knock, etc.
I was on my way from OKC to Wichita Falls, TX and all of sudden the check engine light came on, the engine constantly had that "diesel knock/rattle" and the power went to ****. It won't reach over 2K on the tach and it shifts hard.
Any ideas?
Luckily, I made it safely to my grandparents house in WF so the truck isn't stranded.
If there's anyone in town (Wichita Falls) that has a code reader and doesny have anything going on, give me a holler. 405-641-4947.
Thanks,
Dan
Old May 9, 2009 | 02:56 PM
DangerousDuramax's Avatar
Dan, that is the infamous #2 and/or #7 inject or harness issue. You need to get a scratch awl and punch a hole through the harness connector to re crimp the connection.
Old May 9, 2009 | 03:16 PM
2500HeavyDuty's Avatar
im gonna have to agree with mr T here, happens to LLYs
Old May 9, 2009 | 03:20 PM
Yep, its happened twice on mine. Had to fix the #2 connector on the side of the road the dark.
Old May 9, 2009 | 03:41 PM
Xero's Avatar
Thanks for the responses guys! I hate to show off my ignorance here, but I have no idea what yall are referring to. Where is it and what exactly do I do?
Old May 9, 2009 | 03:59 PM
Each injector has a wiring harness plugged into it with connector. On #2 and #7 the wires are pulled tight causing the crimps inside the connector to separate which in turn keeps the inject or from firing properly. You need to take an awl or an ice pick and punch it through the connector to recrimp the leads.
Old May 9, 2009 | 07:18 PM
Xero's Avatar
Alrighty guys. I think I got it fixed. It turned out to be the #7 harness. I started with #2 (since it was the easiest to reach) and it still acted up. Took the ice pick to #7 and BAM! Sounds good as new.
Thanks a million for all that chimed in. Now, wish me luck on the way back to OKC (I tend to get a little paranoid after doing stuff like this).
Old May 10, 2009 | 06:20 PM
shbeatte's Avatar
mine looses power when you get on it
Old May 14, 2009 | 07:05 AM
Xero's Avatar
Ok, quick question regarding the same issue.
Anyone have an idea if it's normal for the same thing to happen just a few days after I recrimped both #2 and #7?
I was on my way to work this morning and it started shutting down on the highway.
Old May 14, 2009 | 07:23 AM
txredman's Avatar
Texas Mafia
Way to go!! Got a problem solved - thats one of the main reasons for the site!! Good job fellas! Solved quick too!
