New exhaust
Old May 7, 2009 | 08:57 PM
relay93's Avatar
Default New exhaust
Well I got my new Expandit Exhaust, Thanks Diesel Dawg, for my 96 club cab long bed. From what I understand this exhaust is designed for the cc long bed and if you have a reg bed or cc short bed then you have to cut the extensions. Might concern is where the pipe goes over the axle here is a pic.
Does this look right or do I need to cut some pipe off on one of the extension or off the piece going over the axle or do I leave it alone. I am also using the down pipe that came with the new turbo which looks to be the same legnth as the down pipe that came with the kit.
Thanks
Old May 8, 2009 | 01:14 AM
From the angle of the picture its looks good to me.
Old May 8, 2009 | 01:40 AM
FastCR's Avatar
i think you could stand to take off a bit, looks like its a little too fa back but it could just be the angle of the pic.
Old May 8, 2009 | 08:15 AM
DslDeamon's Avatar
looks good to me
Old May 8, 2009 | 05:36 PM
relay93's Avatar
So you guys think that the first bend coming over the axle from the muffler outlet is not to close?
I talked to Doug at Expandit and he told me that the exhaust is built to the longest wheel base i. e. Club Cab long bed for 94-02, that I did not have to trim or cut anything. So if anyone questions distance on their install here is your answer.
Here is an adder. I removed the HX40 style down pipe that came with my turbo and use the one the came with the Expandit kit. The down pipes were bent a little different and the Expandit DP is a little shorter.
Once I put the Expandit DP was installed the fit was just as it was designed. I could have the other DP but decided to put the Expandit in. Hope this helps someone else in the future.
Hope everyone is having fun at TS
Old May 8, 2009 | 10:57 PM
This is one reason why we really don't like saleing the kits without a DP. Seems like everyone does something a little different.
Luke
Old May 8, 2009 | 11:05 PM
relay93's Avatar
I could have cut some length off of one of the extension pipes. I figured approx 4.5" to 5" and this would have put the bend over the axle properly. Luke you will have an example to share with your customers.
Old May 8, 2009 | 11:15 PM
Thanks Buddy
Old May 9, 2009 | 07:06 AM
biged681985's Avatar
glad to hear you got it on roger. hows it sound? ts would be awsome if it wasnt for the rain.
Old May 9, 2009 | 08:46 AM
relay93's Avatar
It is quieter with the TBE 4" compared to the 4" dp to the stock 3" thats for sure. My boost psi is running lower with the full 4" compared to the 4" to 3" stock. With the 4 to 3 at 65 it was 2.5psi to 3psi with full 4 it's at 2 psi. Big difference compared to the stock turbo.
Hey I am glad to hear that you guys are having a good time. I seen on the weather at about 3:15 to 3:30 ,our time, that tornado's were in the Bowling Green, Kentucky area.
Have Fun!
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
