06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
Exhaust Sound??
Old May 3, 2009 | 05:20 PM
94Matt's Avatar
Default Exhaust Sound??
I took the cat and muffler off and put in a straight through muffler about a year ago. The thing sounds like I'm running an air compressor into the exhaust except when I start it up it will sound like the air's blowing then for one second it stops then starts back again. Is this the EGR that I'm hearing or is it just the normal sound of one of these turbos? I guess what I'm asking is, if I block the EGR will it sound less like a sand blaster?
Old May 3, 2009 | 07:02 PM
Oilfield_Mafia's Avatar
What you are hearing is the VGT.. opening and closing slightly.. Perfectly normal.. You oughta hear mine straight piped hru a 6" stack.. sounds like a REALLY loud hissing noise..
Old May 3, 2009 | 07:48 PM
You high tech guys with your VGT and EGR.
Old May 3, 2009 | 07:59 PM
2500HeavyDuty's Avatar
yup it do that noise
Old May 4, 2009 | 08:44 AM
94Matt's Avatar
Pretty much what I figured. Sounds horrible if you ask me, I wish it would sound like it does for that second when it adjusts.
Old May 4, 2009 | 11:00 AM
uwyo_dmax's Avatar
You can make it sound like an LB7 at idle with EFILive
Old May 4, 2009 | 12:30 PM
yup, open up the vanes at idle and itl rumble like its big brother
Old May 4, 2009 | 12:38 PM
94Matt's Avatar
Interesting. Can I still use the Juice and attitude with efi live?
Old May 4, 2009 | 01:15 PM
uwyo_dmax's Avatar
HAHAHA thats right
You can especially if you just have someone tune the vanes down at idle, well maybe would the edge overide the changes to the vane tables? Where in wyoming are you?
Old May 4, 2009 | 04:58 PM
You could.. but it would be pointless.. since EFI live can do everything and more than any Off the shelf programmer..
EFI Live is the last tuner you will ever need for ANY OBD II equipped GM vehicle.
