start then stalls
Old Apr 30, 2009 | 07:03 PM
wvsmoker's Avatar
Default start then stalls
whenever my trucks sits for longer than a hour or so it starts up then stalls then it starts right up again help!!!!! its real annoying
Old Apr 30, 2009 | 09:09 PM
Whit's Avatar
Site Mascot
what is yer fuel pressure showing?
Old May 1, 2009 | 02:50 AM
wildbill's Avatar
Sounds like a faulty fuel pump
Old May 1, 2009 | 10:12 AM
rkadcock's Avatar
N.M. Bombers Director
Sounds like the same problem I had about a year ago. I put a FASS pump in it and problem solved.
Old May 1, 2009 | 03:57 PM
wvsmoker's Avatar
i got about 10psi at idle with a bd lift pump its crazy once i restart it. it runs perfect as usual
Old May 6, 2009 | 08:44 PM
JT1072's Avatar
2003 F350 6.0 This sounds like the same problem I have . I start up fine run down the road about 2 or 3 miles and the truck stalls. I have to wait about 45 minutes to an hour and it will start right up
Old May 7, 2009 | 04:22 PM
wvsmoker's Avatar
mine just starts right up then stalls then starts right back up its crazy
Old May 14, 2009 | 08:27 AM
MRaynor's Avatar
Any updates?
Old May 14, 2009 | 07:32 PM
wvsmoker's Avatar
havent got around to mess around with it,do you the think the batterys have anything to do with it .its crankin over pretty slow now
Old Jun 7, 2009 | 12:17 PM
MRaynor's Avatar
The slow cranking is most likely the batteries, but I really don't think it has anything to do with the other problem you are having.
