95 6.5 TURBO DIESEL WONT START
Old Apr 27, 2009 | 09:25 PM
J-RU's Avatar
Default 95 6.5 TURBO DIESEL WONT START
I HAVE A 95 GMC Z-71 WITH A 6.5 TURBO DIESEL . I RECENTLY REPLACED THE PMD WITH A COOLING UNIT TO START . THEN THE OIL PRESSURE SWITCH AND THE LIFT PUMP .CLEANED THE K/N AIR FILTER AND RE-OILED IT . THE TRUCK RAN GREAT AT FIRST(FOR ABOUT AN HOUR TOTAL) BUT WILL NOT RUN ANYMORE . THERE IS FUEL COMING OUT OF THE T HANDLE AND OUT OF THE TOP OF THE FUEL FILTER WHEN I CHECK FOR PRIME . THE MOTOR TURNS OVER GREAT BUT WILL NOT FIRE . I CHECKED FUSES HOSES AND CONNECTIONS RESET THE ECM THROUGH PULLING THE FUSE BUT NOTHING HAPPENS .I CAN HEAR THE LIFT PUMP WORKING ALSO . THE BATTERIES WERE DISCONNECTED WHEN I REPLACED THESE PARTS SO EVERYTHING SHOULD OF BEEN SAFE . IM LOST , I HOPE SOMEONE CAN HELP.
Old Apr 27, 2009 | 11:08 PM
FastCR's Avatar
hmmmm. Bad connection on your PMD maybe? Only thing I can think of without tearing ish apart
Old May 1, 2009 | 02:41 AM
wildbill's Avatar
I'm not too familiar with the 6.5, but crack an injector line to see of there is fuel coming out when it turns over. If not, you got a bad injector pump or the kill solenoid went out.
Old May 14, 2009 | 08:45 AM
MRaynor's Avatar
Since no updates in a long time, I'm going to assume this is a fixed problem and am closing the thread. If need be, this thread can be reopened.
Brclouse
Nov 18, 2015 08:44 AM
Easton18t
Jul 30, 2015 02:06 PM
penley`
Jun 7, 2015 04:38 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
