help 2004 dodge 2500 cumming turns off
Old Apr 23, 2009 | 01:01 AM
oak1now's Avatar
Default help 2004 dodge 2500 cumming turns off
hey guys so i was driving home and a block before i get home my truck turns off so i turned it back on and boom again shuts off. This happen for about a minute then i was able to start it and park it then it shut off again. it has diesel i tried to rev it and see if it would not shut off but still after a couple of seconds rpms drop and truck dies. what can it be ?? thanks in advance
Old Apr 23, 2009 | 01:06 AM
Red_Rattler's Avatar
High Tech Redneck
How many miles on the truck? Thats what mine would do when the lift pump took a crap. Is your lp still mounted on the fuel filter bowl? If so just turn your key to the run position and you should here the pump kick on instantly. If its silent then time to trouble shoot to be sure thats it, then give AirDog a call. Good luck!
Old Apr 23, 2009 | 01:24 AM
oak1now's Avatar
truck has about 110k. lifter pump what does this do where would it be under my hood and how much they go for? sorry im not too familiar with diesels but is it a easy fix? I need my truck for work so need to fix it right away. how do i trouble shoot it
Old Apr 23, 2009 | 04:48 AM
wildbill's Avatar
I would say, see if changing the battery in your key fob helps. If not, give the other one a try and see if that helps. Might have to have the dealer reprogram them to the truck.
Old Apr 23, 2009 | 11:18 AM
High Tech Redneck
Bill wtf are you talikng about? I sent ya a pm oak
Old Apr 23, 2009 | 12:18 PM
Bills on crack today - tune in tomorrow and he will be feeling MUCH better....
Old Apr 23, 2009 | 01:11 PM
wildbill's Avatar
Your 04 doesn't have a key with the door lock/unlock and panic buttons all in one unit??
Old Apr 23, 2009 | 01:19 PM
wildbill's Avatar
Old Apr 23, 2009 | 01:22 PM
cashwheel's Avatar
06 up only Bill, but you would be right on an 06 it will do that
Old Apr 23, 2009 | 01:48 PM
High Tech Redneck
Nope.... But at least I know what your talking about now I thought you might had lost it.....
