VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
2 Stroke?
Old Apr 21, 2009 | 09:15 AM
06Cummins's Avatar
Default 2 Stroke?
Has anyone ran 2 stroke in their TDI? If so what results did you see. I used 2 stroke in my 06 CTD and I saw mileage increase, was wondering if that would work with the TDI.
Old Apr 21, 2009 | 03:58 PM
big bad diesel 416's Avatar
Site Sponsor
2 stroke what
Old Apr 21, 2009 | 04:36 PM
06Cummins's Avatar
2 stroke oil, like used in lawnmowers.
Old Apr 26, 2009 | 12:32 PM
rivercat's Avatar
yes It quiets the clater when cold on startup
Old Apr 26, 2009 | 02:17 PM
bobcat67's Avatar
I don't know if I'd run anything in your fuel there is way to much controversy on fuel addatives in my opinion, I used to run a bit of powerservice in every tankful and i tried 2 stroke oil out, nothing really did anything positive, granted I didn't have anything that did any negative but if you can't notice a difference why throw money into it? If you get good results more power to ya
Old Apr 26, 2009 | 09:05 PM
vlado's Avatar
i dont know about 2 stroke but i run 2 qts of clean 15w-40 in every tank of my jeep and it does help on mpg
Old Sep 18, 2009 | 11:10 PM
tower_ofpower's Avatar
oil mixed with the fuel adds BTU's... more BTU's more energy to be produced... more energy per same ammount of fuel injected menas you wont lean on the throttle as hard which = better economy... if you drive it hard before, notice a slight increase (mental or actual) in performance and drive it the same or harder... then you wont see an increase. everything is a snow ball effect... for the cost of the 2 cycle oil i'd run it opposed to replacing fuel system parts...
lubrication is everything...
Last edited by tower_ofpower; Sep 18, 2009 at 11:10 PM. Reason: Automerged Doublepost
Old Oct 22, 2009 | 12:47 AM
zrock's Avatar
keep the 2 stroke away from a tdi the fuel systems are so touchy on these things that it dosent take much to screw them up. and the turbos run so hot that it will just creat more trouble than its worth
Sep 21, 2015 08:00 AM
dbszorro
Aug 22, 2015 10:02 PM
Dyesel67
Feb 25, 2015 01:38 PM
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
