dodge disel code -p-1688
Old Apr 20, 2009 | 10:09 AM
albertacummins's Avatar
Default dodge disel code -p-1688
so my buddy has a code p-1688,the obd says internal problem,low power or engine stopped.
it pops up as soon as he starts it.the fuel pump is in the tank he hasnt got a fass or air dog yet .what ideas do you intelligent diesel lover's got? it is an 02'-24 valve . history unknown as he bought the frame with engine and diffs and tranny.
it does run rough
Old Apr 20, 2009 | 11:40 AM
MoeSzyslak's Avatar
I read somewhere that it's an injection pump issue. either that, or it's sensor is probably going or gone. just my idea, somebody with more experience will probably help out more, Good luck!
Old Apr 20, 2009 | 08:42 PM
wildbill's Avatar
P1688 Internal Fuel Injection Pump Controller Failure
Check the connection on the top for corrosion. If corroded, use some battery terminal cleaner or WD40 to rid the corrosion. If it doesn't help, VP44 is it's last leg.
Old May 1, 2009 | 02:28 AM
wildbill's Avatar
Any updates??
Old May 6, 2009 | 03:56 PM
he found out the pump was nfg like they all do sometimes thanks guys
Old May 6, 2009 | 04:16 PM
Resolved and closed.
upnorthwelder
Nov 10, 2015 10:17 PM
thatdude38
Aug 31, 2015 05:22 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
