CEL Code P2262
Old Apr 19, 2009 | 08:17 PM
bowhunter8's Avatar
Default CEL Code P2262
Driving home CEL light comes on. Checked code P2262. Turbo No Boost. Truck runs fine. What to do now. Thanks for any info.
Old Apr 20, 2009 | 02:19 AM
ETXBlueRam's Avatar
It's possible your turbo just needs cleaned. I've had that code more than once. If your internals have a buildup of soot it can cause the turbo to stick and not make boost, which in turn throws the code. Depending on your build date, you may already have the cleanout port on yours. If not, the dealer will drill and tap your housing for a cleanout port. I had mine cleaned recently, along with the EGR cooler, and it made a big difference in the way it runs. Mine wasn't running bad, it just felt a bit down on power. If it weren't for the eco *****, we wouldn't have DPFs or EGR systems and in turn wouldn't have this problem.
Worse case scenario, you get a new turbo...and hopefully it's problem solved.
Something else I thought of that you may or may not be aware of... run your exhaust brake whether you're towing or not, don't let it idle for long periods of time, and if you do have to idle it, turn the high idle on. It's not a cure, but it will help with the soot buildup. On occasion, I will take mine out and run it in 5th gear around 2000 RPMs down the highway for 25-30 minutes. That will help keep the DPF clean, and the 30 minute time frame will complete a regen cycle if one has started and hasn't been allowed to finish. It's less of a pain than going to the dealer and having them force it.
JB
Old Apr 20, 2009 | 02:12 PM
bowhunter8's Avatar
Just got back from the stealership. In a charger, how am i going to hook up my 15k gooseneck? Well turbo needs cleaned, EGR needs cleaned, Oxyegen sensors need wrap, says it will get hotter in regan to remove soot quicker. BLAH BLAH BLAH. will keep yall up to date.
Thanks EXTBLUERAM.
Old Apr 21, 2009 | 04:49 AM
ETXBlueRam's Avatar
You're welcome.. Another thing to check...make sure the G-30 recall has been done on your truck. It involves replacing the oxygen sensor module.
Oxygen sensor wrap? That's a new one to me. The "extra heat" for your regen cycle is generated by extra fuel being injected, which is why your mileage takes a dump when you go into regen.
Old Apr 26, 2009 | 09:27 AM
bowhunter8's Avatar
New turbo, EGR cleaned, New o2's,s and wrapped pipe. Hope this will fix problem. We will see.
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
robbyS
Apr 16, 2015 02:22 PM
J_stout
Dec 14, 2014 07:23 PM
