fuel system?'s
Old Apr 19, 2009 | 08:06 PM
camojeeper@gmail.com's Avatar
Default fuel system?'s
so ive been having fuel psi issues with the hot rod tug boat lately last week i put a new walbro392 pump in because i was running out of fuel psi and now the truck will run low on fuel just going thru the gears could a week fuel pump relay do this or do ya think somthins in the tank? new pump and filter in truck?
__________________
Old Apr 19, 2009 | 09:26 PM
stkdram55's Avatar
Might be your HPOP going out or getting leak
Old Apr 19, 2009 | 10:31 PM
no i got terminator oil this is a diesel problem i got 3000 psi hpo @wot
Old Apr 20, 2009 | 07:38 AM
wizard's Avatar
Default fuel pressure or inj starving of fuel
When you put the fuel pump in the tank did you take the fuel pump holder a part and clean it out ? It splits in half and needs to be cleaned inside. Somtimes dirt gets in there and the pump is not even bad.
Old Apr 20, 2009 | 09:44 PM
ya i found the problem air pre pump some new line and some better clamps fixed it
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
