6bt in a buick regal?
Old Apr 16, 2009 | 04:26 PM
hereismylife's Avatar
Question 6bt in a buick regal?
I was wondering if anyone knows of anyone that put one of these in a regal before. I have the car minus a engine. I just wondering if it could be done. It did have a Pontiac 400 in it.
Old Apr 16, 2009 | 04:32 PM
Red_Rattler's Avatar
High Tech Redneck
Anythings possible.... Theres one with a duramax in it
Old Apr 16, 2009 | 04:36 PM
yea I was reading about this from time to time. I do know you can get the d max in which might be a easier choice to do but the cost factor and working on these would be 3 x as hard. I just think a 6bt would be better because of no electronics....
thanks for the info
Old Apr 16, 2009 | 05:15 PM
High Tech Redneck
yea, the only issues I see are the firewall and front end beef up...
Old Apr 16, 2009 | 07:31 PM
Yea I was doing some measuring and it seems like the engine might be to tall....
As far as the length it seems like it will fit fine.
I have to find the dimension for the 12v motor again and look at it closer.
Old Apr 16, 2009 | 07:49 PM
High Tech Redneck
Cowl induction hood
Old Apr 16, 2009 | 10:10 PM
Yes I think you are right. It seems like it will sit 3 inches higher then the hood
Old Apr 19, 2009 | 07:02 PM
Prankster's Avatar
Yank both engine, and trani, then install the setup as a together unit.
As for the 3" of extra room needed; do a body lift.
If your turbo hose is your problem use an intercooler. Your air supply hoses will be routed foward instead of up, and over, and you might not need the body lift.
Old Apr 20, 2009 | 01:45 AM
rjdyt's Avatar
I saw an A-body '70 Monte Carlo with a '99 ISB 24-valve under the hood on youTube
Old Apr 20, 2009 | 01:56 PM
I am trying to get more info on this car. Thanks
