How much HP?
Old Apr 16, 2009 | 08:55 AM
djwhonda92's Avatar
Default How much HP?
I now have a #100 fuel plate all the way forward, starwheel all the way forward, billet triple disk converter, heavy duty flex plate, stronger high strength clutches, adjusted valve bodies, 370 marine injectors, 4" cat back, boost elbow, billet input shaft, AFE intake and some gauges to watch over everything...
has anyone had a similar setup and ran a dyno?
Old Apr 16, 2009 | 09:18 AM
94 12valve's Avatar
guess with the stock turbo 300-320rwhp
Old Apr 16, 2009 | 10:09 AM
12valvetater's Avatar
something like 330ish and 700 i have a similar setup with a manual
Old Apr 16, 2009 | 10:18 AM
94cummins12v's Avatar
havent gotten on the rollers yet but hoping to quickly, i got just a bit more than you do so im guessing your around 350ish
Old Apr 16, 2009 | 12:38 PM
xzaq103's Avatar
FormerVendor
Id guess 350.
Old Apr 16, 2009 | 01:09 PM
BEERPLAY's Avatar
Originally Posted by xzaq103
Id guess 350.
Old Apr 16, 2009 | 06:08 PM
sstockton's Avatar
Out of a 95 with no real afc mods, I would say 320ish. I'd mod that AFC if I were you. Its a free way to get more power. I ran that set up in my 95, never did hit the dyno though.
Sean
Old Apr 16, 2009 | 06:50 PM
djwhonda92's Avatar
ok thanks guys, i'm gunna run it on the dyno in a month or so then i'll tell yall'
Old Apr 17, 2009 | 04:41 PM
xzaq103's Avatar
FormerVendor
A lot will also depend on the dyno.
Old Apr 17, 2009 | 05:05 PM
94 12valve's Avatar
what is your timing set at?
