04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
installing turbo
Old Apr 10, 2009 | 02:17 PM
b_r_a_d_79's Avatar
Default installing turbo
i just ordered a cheetah turbo and i was woundering anyone had any tips for installing the turbo?
Old Apr 10, 2009 | 03:31 PM
RodZZilla's Avatar
WhiskeyRiver took my mind
Nope. But I will be in the same boat in a couple of weeks. I will see what replies you get.
Old Apr 10, 2009 | 04:17 PM
jpowel29's Avatar
I have not worked on a LLY but at least you won't have to work around the EGR. Up-Pipe/pedistal bolts can be a pain. Have a good assortment of 12pt sockets. A Topside creeper helps. Replace the factory downpipe while you have it apart. If either of you are planning to have the trans worked on anytime soon I would strongly suggest that you tackle the turbo swap while the trans out (you can get to everything so much easier).
I have not seen the Cheetah turbos but they should be a straight forward swap and I assume that they come with any necessary plumbing/hardware/gaskets. Are you both going to run EFILive?
Old Apr 10, 2009 | 08:27 PM
b_r_a_d_79's Avatar
i am running live and i have already got my tranny built so that kinda knocks that choice out of the way and i dont have a top side kreeaper wish i did after i figured out what it was but dont have one.
Old Apr 10, 2009 | 09:55 PM
jpowel29's Avatar
It can still be done. Pull the inner fenderwells, got some swivels, and some Mechanics Wear forearm sleeves.
Old Apr 11, 2009 | 02:37 PM
b_r_a_d_79's Avatar
do you know about how long it will take for a first timer. i have changed them out on a tractor and dodge but never a duramax
Old Apr 25, 2009 | 08:41 PM
LarryJewell's Avatar
I've installed 3 different cheetahs on my truck, takes about 4-5 hours with 2 people
Old Apr 25, 2009 | 08:46 PM
RodZZilla's Avatar
when do you get the 76 Larry? Beach wasn't sure when I talked to him a month ago.
Old Apr 25, 2009 | 08:52 PM
I havent heard, supposed to be pretty soon, but Brayden stays pretty busy, I'd guess mid summer probably.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
