Chevy/Cummins swap
Old Apr 9, 2009 | 02:41 PM
jthomp63's Avatar
Exclamation Chevy/Cummins swap
Hey everyone, got an old body style chevy im lookin to swap a cummins into. Been lookin everywhere online for info and it all seems pretty straight forward. Gotta notch the frame, drop the crossmemeber, make a tranny mount and run hydroboost for more clearance. the only problem is i dont have a 220 volt welder at hand and i cant make everything. im lookin for part sources on MOTOR MOUNTS. they offer something on AutoWorld but ive been told its possible to use the stock motor mount brackets on the cross memeber. Any advise?
Old Apr 9, 2009 | 03:28 PM
Oilfield_Mafia's Avatar
First off, welcome to DieselBombers!
now for your conversion.. check out DESTROKED: Cummins Conversions they have all kinds of motor mounts, and adapter plates to different transmissions.
Old Apr 9, 2009 | 08:42 PM
jthomp63's Avatar
Post chevy cummins
thanks alot, will have to contact them. any suggestions before i do this swap? boxing of my frame necessary? valve cover hitting firewall at all?
Old Apr 9, 2009 | 09:09 PM
Johnny Z's Avatar
got any friends that are weldrs? we usually do side workfor beer!
Old Apr 10, 2009 | 01:38 AM
LOGANSTANFORTH's Avatar
if the truck is an 80's call Avalanche Engineering, they sell a complete tube crossmember for about 400 bucks, its stronger and helps tie the front of the truck together better, also look at a steering box brace for the truck cause that cummins is heavy and thats alot of weight on the nose and it may rip the box out of the frame......another thing is that there is a factory cummins to chevy tranny adapter out of the bread trucks, you just got to find one.....
Old Apr 10, 2009 | 07:37 AM
BigDiesel359's Avatar
Yes we do, some of "charge" more than others though
Old Apr 13, 2009 | 09:40 PM
ChevyClayton's Avatar
Default Chevy to Cummins
Hi, i have a 1996 chevy 1500 4x4, i was wanting to put a 3.9 or 5.9 cummins engine in it. Do you know how big of a deal it is to rewire the engine to hook up to the gages, computers, tranny, etc?
Old Apr 19, 2009 | 07:27 PM
Prankster's Avatar
Do you really wanna easy, and cheaper way of doing your swap?
Move your body over to the other frame.
Or, cut the frame in half, and re-weld it to your truck.
maybe you have $8000 to do the yank, and swap way.
Don't get angry with me; I don't set the prices!!!
Old Apr 19, 2009 | 07:57 PM
FastCR's Avatar
I did mine all with a 120v mig welder. Just beveled EVERY edge for the welds and got 100% penetration. If you take your time prepping for the welds it can be done.
The premade crossmember is pretty trick I'd check that out.
Old Sep 23, 2009 | 11:01 AM
sledman17's Avatar
I got a k30 and wanna put a cummins in it but am i better off to lift the body off and set it on a cummins frame?
