Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Mitsubishi-Fuso / Zexel Injection pump, anyone have info on these?
Old Apr 7, 2009 | 11:17 PM
spoolinaround's Avatar
Default Mitsubishi-Fuso / Zexel Injection pump, anyone have info on these?
looking to put a little more fuel to my Mitsubishi Fuso Fe with a 4 cyl and inline Zexel pump, hell any info I can get on this pump would be better then what I have and can find
Old Apr 7, 2009 | 11:38 PM
wtfd6's Avatar
Bombardier
What are you looking to find out? Get me a pump number.
Old Apr 8, 2009 | 12:28 AM
I just want to squirt a little more fuel Mark, I am not expecting much but christ that truck will barely get out of its own way let alone with a trailer behind it.
Old Apr 12, 2009 | 11:11 AM
nevrenufhp's Avatar
pump numbers and pix do wonders!
Old Apr 12, 2009 | 12:19 PM
well I figured out why my truck was so slugish, it had a torn intercooler boot that I could not see, and I fixed that and it makes more then 3-4 psi of bost now at about 9 now, I found some info on 4btswaps.com and it is the same ajustments on the mitsubishi motors as the 4bd1 just backwards, I want to get a pyro on the truck before I start messing with it cause I am told you can burn these little 4 cyl's up real fast, all I need to do is mess with the aneroid so she starts making boost sooner, it gets 2-3 psi and hangs there for a second or two then starts building up to 9
Old Apr 12, 2009 | 01:08 PM
nevrenufhp's Avatar
only 9? That seems rather low, but without having the factory spec, it's hard to say.
Old Apr 12, 2009 | 02:18 PM
I was told from 10-12 is where it should be for the year it is, right now I will settle for 9ish , cause it is better then 3ish and it will actually go from 0-60 in less then a ¼ mile
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
