1998 jetta tdi
Old Apr 6, 2009 | 06:50 PM
ESI Tech's Avatar
Default 1998 jetta tdi
I have a 98 jetta 1.9 tdi. had a small fire under dash, when fire started the key was off and the motor sterted to run. i unhooked the battery and it stopped. I have fixed the many wires that were burnt together and now it will not start. any help would be great!!!!!
thanks Daryl.
Old Apr 6, 2009 | 07:01 PM
Red_Rattler's Avatar
High Tech Redneck
I'm assumeing when the wires shorted out on each other the ecm most likly got fried along with said wires. A trip to the dealer would sort it out real quick... Welcome to DieselBomers as well.
Old Apr 6, 2009 | 07:06 PM
ESI Tech's Avatar
That is what i thought also but there are no codes and i should of mentioned that it will run but i have to give it a little starting fluid(yes i know that isn't good). i have no fuel coming out of the pump to the injectors and good fuel coming into pump.
Old Apr 6, 2009 | 07:07 PM
DB Admin's Avatar
Banned
Fuseable link could of burned up as well
Old Apr 7, 2009 | 11:43 AM
ESI Tech's Avatar
ok i have some more info. i took the plunger out of the fuel cutoff valve and pulled the of the pump off can move quantity adjuster and it will start up. Is this a pump problem or a wiring problem?
Old Apr 7, 2009 | 12:39 PM
High Tech Redneck
If the car ran b4 the fire I'm still gonna go with wires. But get a multimeter and see if there is power going to the solinoid to activate the plunger to open. Could still be ecm which I guessing would control the shut off valve.
Old Apr 8, 2009 | 12:12 PM
Buckshotmckee's Avatar
Sma't Alec!
Those cars are notorious for bad ignition switches, I would replace it and go from there. Also, on the firewall is a large fuse, more like a flat piece of pot metal, that's probably cooked as well.
Old Apr 8, 2009 | 05:07 PM
ESI Tech's Avatar
Well buck you are correct. i put a switch in it this am and it started right up. Thanks to all that helped!!!!!!
Thanks again!
torino73
Apr 14, 2015 11:15 PM
Feb 12, 2015 01:10 PM
Dec 22, 2014 09:00 AM
Nov 24, 2014 08:20 AM
Oct 9, 2014 08:10 AM
